41 B oil pump drive coupling
donwisc
03-07-2005 17:31:25
Just got my parts to continue on the rebuild of this B and coulnt believe what the new designed pump shaft coupling looked like.
Its round with the sq hole but it also just matches my 1/2 inch drive 9/16 socket. All I would have had to do is cut off the socket portion and use the sq drive end. A lot cheaper than the 15.00 one from deere.
Maybe this will help someone else save a buck
DAVE NE IA
03-07-2005 17:47:26
 Re: 41 B oil pump drive coupling in reply to donwisc, 03-07-2005 17:31:25
Probably the biggest objective of this coupling is to shear off if the pump should freeze etc. Your socket mayby not such a good idea. Perhaps a person could cut the socket in one place very thin so it would shear. Just my passing thoughts. DAVE NE IA
donwisc
03-07-2005 19:21:05
 Re: 41 B oil pump drive coupling in reply to DAVE NE IA, 03-07-2005 17:47:26
Dave I thought the same thing. The original coupling that sheared was just a thin piece of sq tubing and did provide a safty shear point but the new Deere coupling is made just like a 1/2 inch dive end of a socket. Somethig else will now break.
DAVE NE IA
03-08-2005 21:21:07
 Re: 41 B oil pump drive coupling in reply to donwisc, 03-07-2005 19:21:05
Perhaps I have alot to learn, so thank you for the information. It has been 20 plus years ago I did the poor boy fix by using a piece of 1 inch or perhaps 1 1/2 11 guage square tubing, I just can't remember, but it sure seems to me it was a exact copy of the original. So thanks again for the information that I hope to retain. Dave NE IA
