4520 cbc roosa master
twopop
03-07-2005 17:22:20
really need to talk to an expert on cbc pumps
jdemaris
03-07-2005 19:49:37
 Re: 4520 cbc roosa master in reply to twopop, 03-07-2005 17:22:20
I don't consider myself an expert anymore on C pumps, but I've fixed a lot of them years past and I still have all the specs for them here. Deere phased them out in the early 80s and was selling kits to change over to JDB or JDC pumps. I did all the pump work at our dealership, but most were Roosamaster JDB and DB2, or CAV pumps. So, maybe I can help, maybe not. What do you want ot know? If you want any specs., give me the Deere part # or the Roosamaster part #.
twopop
03-07-2005 20:13:58
 Re: 4520 cbc roosa master in reply to jdemaris, 03-07-2005 19:49:37
I have repaired some jdb pumps but never a cbc.I am havin a problem getting it to run right.do have 1 bad injector and have ordered a new one,it seems to be out of time (retarded),if i screw out the advance screw,it runs better,but still not right.took the pump off and it appears to be set correctly,going to check the drive gear tomorrow,possibly something with the cam.the engine smokes alot,will not run except with some either added,until it gets warm,or at high idle.im beginning to think it not the pump.
jdemaris
03-08-2005 05:51:50
 Re: 4520 cbc roosa master in reply to twopop, 03-07-2005 20:13:58
Usually, worn injection pump components will make the engine run worse, not better, as it warms up. To the converse, a worn diesel engine (pistons, sleeves, etc.) will usually run better as parts gets hot. I've got all the factory diagrams, schematics, and repair info if wanted for all the C series pumps. In regard to the fuel advance, it works the same as the DB series, i.e. it works off of internal transfer pump fuel pressure. Early C pumps had problems with the transfer pump vanes wearing out and there were "improvement kits" for them. You can check the advance with the engine running by putting a plastic degreed window on the pump, part # 17180. Also, you can just advance the entire pump manually by rotating it a bit and see it runs better as high end. Even if this works, it's not a good permanent fix since the engine will then be overadvanced at low speeds.
msb
03-07-2005 20:40:05
I am like jdemaris.Its been a long time but one I do remember giving me total fits was when the small air separation orfice was plugged up and I couldn't tell it.Took me one whole afternoon to figure it out.Remove the air separator and run a nozzle tip cleaner through the hole to be sure it is open.I can't remeber the size of hole it is but it is very small.It serves the same purpose as the vent wire in the DB pumps.
twopop
03-07-2005 20:55:54
 Re: 4520 cbc roosa master in reply to msb, 03-07-2005 20:40:05
i guess your going to have to give me more info.i dont know where the hole is,nor the air seperator.
msb
03-08-2005 07:58:21
 Re: 4520 cbc roosa master in reply to twopop, 03-07-2005 20:55:54
Its the plug with a plug in it towards the top of the side of the pump.The small plug is simply a drain plug.Remove the larger of the two.That is the air separater.Thought you might have a book,sorry.
