37A PTO engagement
leo
02-18-2004 08:37:19
Guys and Gals,
I have gotten enough answers on this forum to keep me busy for days.but here goes one more:
How do I engage the PTO ?
It does work ,but I do not know what I did to get it running . Or is it supposed to work as long as the engine is running?
My tractor has three levers :forward-reverse , 1-2 and H-L .
Thanks in advance.
leo
Clooney
02-18-2004 13:18:40
 Re: 37A PTO engagement in reply to leo, 02-18-2004 08:37:19
third party image
Leo, see picture of PTO control on a 37 A [give it a minute to load],, The lever is as marked & you move it to the Left [clutch MUST be disengaged, or engine off] to engage it..
~The PTO on the 37 A is [NOT LIVE] so if the lever is moved to the left [engaged] the PTO shaft spins any time the clutch is engaged,, or if the tractor is moving with the trans in any gear..
[email protected]
John T
02-18-2004 09:12:44
Hey Leo, As far as your first question: First, you dont have "live" PTO, so the clutch must be engaged before the PTO turns. Second, there is also an engage/disengage lever on the floor which MUST also be engaged before it will turn at all (still clutch needs to be in).
To answer your second specific question, NO its not necesarily gonna turn just cuz the engines running, the engage lever PLUS the clutch BOTH must be engaged.
On the later "live PTO" tractors, if the PTO is engaged, it continues to turn regardless if the clutch is on or out.
Take care, God Bless, n post back or e mail any questions [email protected]. Good luck wiht the old girl
John T
Joe
02-18-2004 09:07:31
Leo, I'm going to bet that the lever you're saying is forward-reverse is small, on the right, and ahead of the lever marked high-low. That one is the PTO control. You have to have the pulley stopped in order to engage the PTO. You can disengage the PTO with just a quick jerk and not stopping the clutch pulley. BTW, if you have a power-lift, the PTO must be engaged to use it.
The other two levers determine what gear you're in: 1L is first, 1H is second, 2L is third, and 2H is 4th. In 4th, you should be smokin' down the road at 4 1/2 mph!!!
