1946 G timing
Great Dain
03-07-2005 14:47:32
How many degrees BTDC do you set a G at??? Timing one with a light and don't have a service manual.
Thanks
Duane Larson
03-07-2005 20:28:07
 Re: 1946 G timing in reply to Great Dain, 03-07-2005 14:47:32
Great Dain,
JD specs call for 25 degrees BTDC if burning gasoline.
Will P
03-07-2005 21:12:10
 Re: 1946 G timing in reply to Duane Larson, 03-07-2005 20:28:07
Duane, is that at full 975RPM"s? Delco dizzy on my 51G. Have to time yet.
Thanks!!!!!
Will P
Duane Larson
03-08-2005 05:30:54
 Re: 1946 G timing in reply to Will P, 03-07-2005 21:12:10
Will P,
Yes, that is at 975 rpm. I probably have the advance curve for degrees at other rpm if you need them. I assume you have the normal Delco 1111558 distributor.
Will P
03-08-2005 14:16:33
 Re: 1946 G timing in reply to Duane Larson, 03-08-2005 05:30:54
Junk yard Delco off of an early styled A. I will get the number. Rebuilt it with new Deere springs out of the parts book. She has M&W pistons in her with a cold manifold. Just got her running after the previous owner giving her a 27 year nap. He kept the Wico dizzy. I didn't want it either. LOL
Thanks,
Will P
Garland(Gman)
03-07-2005 16:55:45
Great Dain I align the marks on flywheel and case as outlined in books,on my puller I set the timing at about 18-20 Degrees on my timing lightand then align marks on flywheel and case.I know this kinda vague but it worked for me. Gman
