730 D FLYWHEEL
Scotty
03-07-2005 06:55:35
ARE ALL 730 FLYWHEELS THE SAME ? I HAVE FOUND ANOTHER FLYWHEEL FOR MY 730 DIESEL BUT IT DOESN'T LOOK THE SAME AS THE ONE I GOT ON THE TRACTOR NOW. THE ONE I HAVE HAS TWO BOLTS THAT DRAW THE FLYWHEEL TIGHT TO THE CRANK AND TWO THIN NUTS ON THE OUTSIDE OF THE CRANK THAT TIGHTEN AGAINST THE FLYWHEEL. THE FLYWHEEL THAT I HAVE FOUND DOES NOT HAVE THE BOLTS THAT DRAW IT TIGHT TO THE CRANK AND IT HAS A HUB IN THE CENTER OF IT. WILL THIS FLYWHEEL WORK ? THE MAN SAYS IT CAME OFF OF A 730 FOR SURE...THANKS FOR YOUR TIME AND HELP...SCOTTY
720Deere
03-07-2005 08:33:38
 Re: 730 D FLYWHEEL in reply to Scotty, 03-07-2005 06:55:35
You are definitely talking about a taperlock flywheel. It is not a reworked original, but a new casting with the tapered hub installed. If you can get it cheap enough, I would not hesitate to buy it. They work great and you never need to worry about it coming loose. If you play your cards right, you can measure your clearance before you do the final install and have the hub machined down or shortened to give you enough flywheel cover clearance. I am in the process of this right now. I will post the cost of machining when I get it back from the shop.
Carl NY
03-07-2005 08:48:20
 Re: 730 D FLYWHEEL in reply to 720Deere, 03-07-2005 08:33:38
Becareful when machining the hub as it should have balancing marks that need to be lined up with the crank. If they need to be cut off, be aware of were they were and remarked.
720Deere
03-07-2005 09:41:59
 Re: 730 D FLYWHEEL in reply to Carl NY, 03-07-2005 08:48:20
Carl NY,
The matching marks for flywheel balance are on the outside end of the hub, we are machining the inside end so the flywheel will sit closer to the tractor.
Mike M
03-07-2005 11:25:09
 Re: 730 D FLYWHEEL in reply to 720Deere, 03-07-2005 09:41:59
Just watch it doesn't end up too close. I had one once that when drawed up tight the ring gear was engaged into the starter drive. I had to put a big washer behind to space it out.
720Deere
03-07-2005 11:54:54
 Re: 730 D FLYWHEEL in reply to Mike M, 03-07-2005 11:25:09
This one is about 0.375" offset right know. This measurement is based on a known original flywheel. This also corresponds with the amount of shimming needed for the cover to clear.
We are going to take 0.250" off the hub and will still be about 0.125" offset, but it should clear the cover and the starter just fine.
Thanks for the reminder.
Carl NY
03-07-2005 07:21:37
From your description I would say you have what is known as a taperlock flywheel. The flywheel has been modified to tighten properly on a worn crankshaft. When properly installed the taperlock flywheel will do an excellent job. On some taperlocks you may have to shim the flywheel cover out to avoid the locking collar from rubbing on the flywheel.
Mike M
03-07-2005 07:16:40
That sounds like one of those aftermarket taper lock flywheels. If your splines are worn or if you are having trouble keeping your fylwheel tight now this is the type you would want.
dcotton
03-07-2005 07:16:16
I think if it has a big square nut in the middle its a taper loc style flywheel made to fit on damaged spline crankshafts...
