730 D THANKS !
Scotty
03-07-2005 06:25:37
THANKS EVERY BODY FOR YOUR HELP WITH THE STUCK VALUE ON MY 730 DIESEL. I COULDN'T DESIDE IF THE VALUE WAS STUCK OR BENT AND YOU ALL HELP ME THROUGHT IT. I ENDED UP FREEING THE VALUE WITH A TOOL FROM CHANNEL LOCK IT LOOKS LIKE A DRILL CHUCK BUT CAN BE TURNED WITH A 3/8 RATCHET , SO I PULLED THE VALUE SPRING OFF AND PUT THE CHUCK ON THE END OF THE VALUE STEM WITH A 3/8 AIR RATCHET AND A LOT OF PB BLASTER AND SPUN AWAY PUSHING IN AND PULLING OUT ON THE CHUCK WHILE IT WAS SPINNIG THE VALUE ,SPRAYING IT WITH THE BLASTER UNTIL I COULD PUSH THE VALUE FREELY IN AND OUT AND NOW THE SPRING RETUTNS THE VALUE GOOD ! IT'S HARD TO BELIEVE THAT OIL AFTER SETTING A LONG TIME CAN GET THAT HARD AND CAUSE THIS PROBLEM BUT I THINK THAT'S WHAT IT WAS ! THANKS AGAIN....SCOTTY
