630 Shifter/Gear Problems
HighGear
03-07-2005 03:23:12
A little over a year ago, we bought our first John Deer ("630"). Tride plowing with it last spring and discovered that it would not stay in 2nd gear. Any thought on what is causing this? Is it a simple fix or a major transmission repair? Thanks for your help.
donmyeil
03-07-2005 14:16:41
 Re: 630 Shifter/Gear Problems in reply to HighGear, 03-07-2005 03:23:12
is the shift lever snaping into the detent before the lever hits the end of the slot? this can be adjusted. however the bearings on the top shaft probably need replaced as well as 2nd gear. the gear is probably worn at an angle now. the shifer fork will have wear as well. also a possibility is the shaft could be bent.
