420 lockup seems to be clutch shafts
denjoe
03-06-2005 16:28:07
Removed shifter assembly and rear housing plate. Everything looks fine including R&P. Trans gears all look excellent. No parts or pieces laying on bottom. It seems to be locked up between the clutch and the trans. I have the continuous pto and looking at the diagram in the manual it looks like the inner and outer shaft could have broken or something. With clutch engaged, starter will not turn. Pulled starter and clutch appears fine. Any thoughts?? Guess splitting the tractor is next.
John Buvala
03-07-2005 15:06:05
 Re: 420 lockup seems to be clutch shafts in reply to denjoe, 03-06-2005 16:28:07
I have one the starter is what locks for me.
Especially if it is converet to 12 volts. Next
it happens loosen starter and reinstall it.
should take care of problem.
good luck
John
CPeter
03-06-2005 16:30:43
My guess is that you stripped the splines INSIDE the coupling on the rear of the propeller shaft. Been there, done that.
CPeter
