4239 pistons
Frank in FL
03-06-2005 15:55:35
I am rebuilding a 4239 in a 1975 2130. The JD tech manual indicates that pistons should be replaced with same type (B or H)if block is not changed. With B pistons (this is what was in the engine)and new rod bearings the pistons are .003 below top of the block. If using the information in the tech manual this would indicate type H pistons are needed. Should I get H pistons to go in this engine. I obtained this tractor used with bad exhaust valves so do not know how well it started cold.
buickanddeere
03-06-2005 18:48:21
 Re: 4239 pistons in reply to Frank in FL, 03-06-2005 15:55:35
The pistons have to be as absolutely as high as possible. With the valves & seat as high as possible. Both heights of course without whacking a piston into the head or valves into a piston when at TDC. Some of those later series pistons had a higher top ring for better starting and lower emissions.
