H rear end oil
its all about m
02-18-2004 06:15:59
Just got home with a model H. I can't for the life of me figure out how to check the rear end oil. Can someone point me in the right direction.
jerry
02-18-2004 22:59:30
 Re: H rear end oil in reply to its all about me, 02-18-2004 06:15:59
your best bet is to drain it completely, pull the rear cover and brakekleen it out, or what ever method you see fit. It holds 12 quarts, or 3 gallons of 80/90. hope this helps! Jerry
Mike M
02-18-2004 07:44:00
On the left hand side-flywheel side- side of the transmission case you will find a large round tin plug below this is a pipe plug 1/4 inch pipe size I think, take this out and fill until oil runs out. It would be a good idea to change the oil or at least loosen the drain plug and let the water drain off first.H's get a lot of water in them through the shifter if left outside.
its all about me
02-18-2004 08:16:17
 Re: Re: H rear end oil in reply to Mike M, 02-18-2004 07:44:00
Thanks. I haven't gotten a manual for it yet.
