Clutch Lining Thickness ?
DPOST
03-06-2005 13:46:26
Hi Gang;
Looking at my dissambled GM clutch. Does anyone know what the thickness of the facing material is when it is new? Or what the wear limits are? The facings rivitd to the plate are down to the brass on the rivits, so they will need replaced. I'm trying to figure out if the floating facings also need replaced as well.
Also does anyone have experience with aftermaket clutch facings? Are they as good as the ones from Deere at a third the cost?
Thanks in advance
D.D.Post
Mike M
03-06-2005 16:45:30
 Re: Clutch Lining Thickness ? in reply to DPOST, 03-06-2005 13:46:26
On those floating disks hold one flat in your hand and wave it up and down if you feel it wiggle it is too thin or oil soaked and should be replaced. Since your center one needs replaced I'd just go ahead and put in the new floating ones also. Shouldn't cost that much more and should last a lifetime. I have not used the aftermarket linings yet,but I have used many other aftermarket parts with good success and I would not hesitate to use them if I could save 1/3 the cost.
