Bought a 4230 yesterday!
R. John Johnson
03-06-2005 11:16:29
Bought a 4230 yesterday. 1973 model, 9600 hours showing and has a3 point hitch. She's no parade queen, but everything seems to work. Engine starts right up , no smoke or unusual noises, no puffing through the vent tube. Cab and seat are fair to good. Have to do some minor things to her. The wheels need to be widened out to bale, ISO coupler kits need to be installed and a hydraulic leak on a coupler fixed.
Hope to get many good years of service out of her. I think I will hang on to the 4010 for now. Maybe next year, if finances improve I will overhaul her.
John
txblu
03-07-2005 06:44:38
 Question guys in reply to R. John Johnson, 03-06-2005 11:16:29
On the 4230 with the soundguard cab and controls on the right side:
(1)The remote levers can be pushed forward if the plastic hootus is raised. After experimenting it appears that this takes hyd pressure off the QD's so you can engage the implement????? ???
(2)Between the QD's is a lever about an inch long that can be flipped left or right. Function????? ?
(3) Muffler/exhaust pipe. Coming off the ex manifold is a flange of at least 3" in dia. Muffler input fits this fine. Muffler is oval and fits nicely into the oval cutout in the tin. Top of stack is just above cab with a rain guard as it should be.
Question: Output of the muffler and pipe are only 2" OD (maybe 2 1/8 like in the book if I look closer). Seems to me that this is pretty restrictive for a 404 cu in engine. What gives???
I spent over $250 on manuals this year for other things. This baby will have to wait till next year.
Thanks,
Mark
Txsprigger
03-07-2005 09:03:24
 Re: Question guys in reply to txblu, 03-07-2005 06:44:38
1) Like RJJ said, that is the float position. Hoses easier to connect/disconnect, and allows wheels of implement to ride on the ground while plowing.
2) That is the speed response control lever. Left is slow, right is fast.
3) Don't understand the purpose of that, either. I would see if a 4240 muffler would fit, looks like they have a bigger diameter outlet.
txblu
03-07-2005 12:04:36
 Re: Question guys in reply to Txsprigger, 03-07-2005 09:03:24
Hey Sprigger,
1. I really like that especially in trying to connect a cylinder that is sitting in the sun.
2. So what is center?
3. Me too but I have seen lots of tractors with small stacks. Gotta be sumpin to it.
Thanks for your responses..... ..Texas buddy.
Mark
Txsprigger
03-07-2005 12:48:43
 Re: Question guys in reply to txblu, 03-07-2005 12:04:36
Glad to help.
Middle would be medium on the flow rate, I guess. Most all I have seen or been around are set all the way to the right, or as fast as it can go.
BTW, how are you enjoying retirement??
Too wet to plow?? I think we could bog a snipe with shingles on his feet down here.
txblu
03-08-2005 05:34:14
 Re: Question guys in reply to Txsprigger, 03-07-2005 12:48:43
Retirement?
Really not what I expected. Cashed in some money I have been saving all my life. Had a new shop built for tinkering with old iron, put in some new equip, bought a magnificent 4230/cab and new 134 AC system,with 3990 orig hrs and a professional cosmetic going over, upgraded my round baler from Hesston 5580 to JD 530, and swather from NH 489 to JD 1209.
Heard that once retired you wonder how you had time to work before. That is true. Did not expect that. Between the new toys, getting things ready for spring hayin, workin with the wife on her projects and fixin the 25 year house up, and kicking back when I feel like enjoying the country air (and a beverage of choice), it's been an eventful 2 months.
Hope everyone that retires has as much fun as I am having.
Thanks for asking and thanks for the help. Hope WE enjoy our 4230's.
Has certainly been wet. Don't remember the last day of full sun;;;;;;musta been last summer. Grin.
Mark
buickanddeere
03-08-2005 06:53:37
 Re: Question guys in reply to txblu, 03-08-2005 05:34:14
Looking the gauge up on the JD online cataloge might show the temps as well?
thurlow
03-07-2005 09:55:49
The sprigger is right; 1. float position 2. oil flow regulator 3. ain't got a clue
txblu
03-07-2005 12:06:02
 Re: Question guys in reply to thurlow, 03-07-2005 09:55:49
You're an honest man Turulow. Honest man can put his head on the pillow at night and sleep peacefully. Grin.
Thanks,
Mark
buickanddeere
03-07-2005 14:21:38
 Re: Question guys in reply to txblu, 03-07-2005 12:06:02
Mid to near red temps are good. That is where the engine is running the cleanest and most efficient. The coolant should be at least 180F and 195F is better.
txblu
03-08-2005 05:35:51
 Re: Question guys in reply to buickanddeere, 03-07-2005 14:21:38
Maybe I'll email mother Deere and see what the real temp range of their colored gauge happens to be.
Thanks,
Mark
R. John Johnson
03-07-2005 08:07:09
Mark
I'll try to answer your questions, but I didn't get a manual with the tractor and it is still at my cousin's shop to have ther rear wheels moved out. I'm ordering the operator's manual today and will be prowling e-bay for shop and technical manuals.
1) I think that lifting the plastic stop allows the valve to go into float position. It does on our 2755 with SGB.
2)Not sure. Is this to allow coupling under pressure? BTW does yours have Deere or ISO couplers?
3)Mine was the same when I was looking at her on the lot. With the engine running it almost made a whistle at the top. Compared to the 4010 it looks small.
Have you done much with yours yet? The only worry I had about choosing a 4230 was a reputation for poor fuel economy. I will be using it on a round baler and a 12 bale capacity bale carrier to haul hay. Drop me an e-mail if want to compare more notes later
rjj001 at mts.net
John
txblu
03-07-2005 12:01:20
 Re: Question guys in reply to R. John Johnson, 03-07-2005 08:07:09
I'll hit it here if that's OK.
Just got mine. Only work was with a 20 ft JD spike harrow I went over the winter layby field to smooth it out from last fall's plowing. Was in about mid range gears running just under PTO rpm and after an hour or so the temp crept up over center. Not sure about that. May have over loaded it, radiator is clean, water solution clean, will have to run it more to tell. Thought small exhaust may be the problem.
This is not a turbo (like that; one reason I bought the 4230 rather than the 4440) but have heard that turbo's run hot if you don't open up the output with a big pipe....dunno.
On fuel economy I drove mine from point of purchase 36 highway miles to the house and hardly noticed the fuel gauge move. I think that is impressive. Will see what she does under load.
Have noticed that the smaller stacks make the engine seem to run smoother and quieter. Have a 4010 with a straight 3" pipe. Roars (need ear plugs) but sounds good..... ..
Had to run my wheels out also. First order of business was a good doping of everything with Kroil penetrating oil.
The hammer thing is what it took. Loosened the lock bolts then we used an impact on the 2 screws that push the shims out. We'd beat on the axle a couple of blows with a 20 lb sledge, then hit the screws a couple of pops with the 1" impact. Back and forth and back and forth.
The actual movement was a snap. The screw moved the wheel out at a faster pace than I expected. When finished, we backed out the wedge screws a couple of turns and locked down the lock bolts.
Think I'm gonna like this tractor.
Best,
Mark
SJG
03-08-2005 19:04:36
 4230 load in reply to txblu, 03-07-2005 12:01:20
We have a 4230 and pull a Unviferth 3 shank subsoiler. The 3 shanks put a load on the 4230. Go about 5 hrs. on a tank of fuel. She sucks it down under the load! It takes alot to pull the soiler.
buickanddeere
03-07-2005 14:19:00
 Re: Question guys in reply to txblu, 03-07-2005 12:01:20
Re-torque those hubs. I almost ended up looking stupid at a show with a wheel that came loose. If a 4230 is using that much fuel it's either a long days hard work. Or there is a problem with the airfilters (two) or the injection system.
txblu
03-08-2005 05:47:33
 Re: Question guys in reply to buickanddeere, 03-07-2005 14:19:00
Hubs, good idea.
Thanks,
Mark
R. John Johnson
03-07-2005 13:16:58
Mark
That fuel consumption on the road sounds good. Had a neighbor tell me his 4230 would barely bale a full day on one tank of fuel. This was using the same baler as me. I know the tank on a 4230 is not huge, but that sounded like a substantial jump in fuel consumption over the 4010.
The hydraulic speed control lever does have its uses. When we pull a rake with our 2755 we have to set it at the slowest speed to keep it from violently jumping up when you lift it. Not only does it let you actually set the height, it would certainly damage the rake if left on full bore.
John
txblu
03-08-2005 05:45:05
 Re: Question guys in reply to R. John Johnson, 03-07-2005 13:16:58
I have put enough time on this engine to tell you that it is not hungry. Don't know the exact compsumption as I did not fuel it up nor fuel it up when I got home. Just that the gauge hardly moved over the trip. 36 miles (and about 3 hrs clock time)is a lot of miles for a tractor.
Had an IH 464 that used a half tank of gas (6 gal) to go to town to get gas when I first came out here. Town is 4 miles distant. Quickly realized that I had to do my own refueling AT HOME. Ha!
On the flow, just sold the NH 489 haybine. Previous owner had a restrictive orfice embedded behind the connector for just that purpose. Hole diameter was like .100 inch. Mother Deere's 24 gpm was so much that the thing would jerk to full up and slam to the ground. I know as I didn't know what the orfice was for and took it out. Then I put it back. Grin
Chow,
Mark
cannonball
03-07-2005 13:59:13
run 4230 here baling, uses between 4 to 4.5 gallons an hour...depends how thick the hay is..running a 566 baler...5x6 bales...have nice day may god bless
txblu
03-08-2005 05:46:13
 Re: Question guys in reply to cannonball, 03-07-2005 13:59:13
That sounds more like it.
Mark
buickanddeere
03-06-2005 13:31:56
 Re: Bought a 4230 yesterday! in reply to R. John Johnson, 03-06-2005 11:16:29
Good choice.
Dave Brennan
03-06-2005 16:03:34
 Re: Bought a 4230 yesterday! in reply to buickanddeere, 03-06-2005 13:31:56
We have a 4230 on my dads farm that he puchased new. It has been a great tractor. Good Luck and Happy trails with her! Dave!
