Compression Testing an R Diesel
DHunt
02-18-2004 05:59:41
What is the process for testing compression on the R? Can't find any reference to it in JD or IT service manuals. Failing a compression test, what is the best way to determine if a running engine is ready for a rebuild?
Gpower
02-18-2004 15:50:23
 Re: Compression Testing an R Diesel in reply to DHunt, 02-18-2004 05:59:41
Do the process like Duane wrote, you will have to have like a old injector, that has been adapted to screw in the gauge. You could take an old injector and make it work, as there is no way to scre in just a compression gauge. It would have to clamp in like the injectors do. May need to watch for fuel shooting out from the injector lines as well..it will come out there at a good pressure, so be careful. Good luck
Gpower
Duane Larson
02-18-2004 09:49:00
DHunt,
The R shop manual from JD is pretty sparse. The manuals for the 70D, 720D, and 820D give good instructions for compression testing in the "tune-up" section. Paraphrasing from those manuals:
Since the diesel is free breathing, make sure the air cleaner and complete air supply system is clean. Run the engine until up to operating temperature, shut it off, remove the tappet lever cover and injection nozzles (820D instructions, do comparable work for the R). Screw in the gauge. Start the cranking engine, and with speed control in "stop" position, motor the diesel engine on full compression until the gauge reads max. Repeat for other cylinder, and compare the readings - should not differ by more than 25 psi. For the R the motoring compression pressure should be 440 psi, and the motoring rpm should be 210.
DHunt
02-18-2004 13:01:18
 Re: Re: Compression Testing an R Diesel in reply to Duane Larson, 02-18-2004 09:49:00
Thanks Duane. Do you use a typical truck type compression tester or do I have to find something unique to adapt to the injector port?
Duane Larson
02-18-2004 13:14:07
 Re: Re: Re: Compression Testing an R Diesel in reply to DHunt, 02-18-2004 13:01:18
DHunt,
I don't own a diesel (tractor), so quoting from the manual - they apparently use a gauge with adapters which screw into the port, as they recommend using a new copper washer on the adapter and tighten the clamp nut securely.
Sounds like a good idea to have a tight connection to get an accurate reading and for safety with the high compression pressure.
One of the JD Field Service Bulletins contained a brochure from the Bacharach Industrial Instrument company, which sold a Motorite gauge unit to measure compression in the various JD diesels.
Mike M
02-18-2004 07:46:06
A dyno test of HP and watch for blow by would be a good way to test.
