2010 overheating
Fred Tedescucci
03-06-2005 09:56:56
I have a 1965 JD 2010 diesel (4 cylinder) that lately has begun to show signs of overheating. Until recently the temp gage has always held rock steady on "N" - right in the middle. But after a couple of days of bush-hogging it seems to want to creep up to about the 5/8 or even 3/4 mark. Now I am a "hobby farmer", only using the tractor for needs that arise from time to time and have never "pushed" the tractor. In fact, I don't think I'm "pushing" it now - only running about 1600 RPMs while hogging. Here's the question: Are there any traits that this particular tractor has that I should be alerted to?? As I said, I'm just a "hobby farmer", so I really do need some help here... "THANKS" in advance...
Fred
Roy Suomi
03-06-2005 19:01:48
 Re: 2010 overheating in reply to Fred Tedescucci, 03-06-2005 09:56:56
You stated that the engine appeared to be overheating with the gauge in the N position.You might have to reseal the injector precombustion chambers.. It might be putting compression into the coolant from leaking copper sealing rings between the chambers and the head.The precombustion chambers have 4 bolts holding them down. These bolts have 2 different torque values.Many people torque these to the same torque. Not so.....
thejdman01
03-06-2005 18:57:12
my personal humble opinoin is that you shouldnt have to worry about flushing the radiator and system for this particular instance. definitly have to clean the outside and the screens but usually if the internals are getting plugged up it will gradually get worse as the stuff builds up. can be the thermostat. have seen more instances where they stick open or wont open usually once they stick wont fluctuate. do you notice it heating up quicker then before (i know never really noticed until you got a problem but then its too late) but if shes heating up quick i would say the thermostat is sticking partially closed. thermostats are throw away items. one thing that i will argue to the death about is not only makeing sure the belt is tight but that the belt isnt riding down in the bottom of the grove. i dont give one rats tail how tight you pull on a belt you will just knock bearings out the pully is designed to v quicker and steeper then the belt. so as you tighten it it pulls better. after wear etc i dont care how tight you tighten that belt you will not get belt to actually pull. it will slip. the v in the pully has to be steeper then the belt. im sorry for going off on a tangent but i dont know how many times i have seen with my own eyes and got into arugments about the belt is tight or the belt is new and after you put a new pully on it or put the old one carefully in a press it works all the sudden. also make sure your radiator is clean and dont bend the fins. son ontime when younger tried cleaning the radiator w/a wire brush. he also sat there and straightened every fin w/a small screw driver. make sure the fins are open
thejdman01
03-06-2005 18:55:06
my personal humble opinoin is that you shouldnt have to worry about flushing the radiator and system for this particular instance. definitly have to clean the outside and the screens but usually if the internals are getting plugged up it will gradually get worse as the stuff builds up. can be the thermostat. have seen more instances where they stick open or wont open usually once they stick wont fluctuate. do you notice it heating up quicker then before (i know never really noticed until you got a problem but then its too late) but if shes heating up quick i would say the thermostat is sticking partially closed. thermostats are throw away items. one thing that i will argue to the death about is not only makeing sure the belt is tight but that the belt isnt riding down in the bottom of the grove. i dont give one rats tail how tight you pull on a belt you will just knock bearings out the pully is designed to v quicker and steeper then the belt. so as you tighten it it pulls better. after wear etc i dont care how tight you tighten that belt you will not get belt to actually pull. it will slip. the v in the pully has to be steeper then the belt. also make sure your radiator is clean and dont bend the fins. son ontime when younger tried cleaning the radiator w/a wire brush. he also sat there and straightened every fin w/a small screw driver. make sure the fins are open
thejdman01
03-06-2005 18:55:33
Tim A.
03-06-2005 16:48:57
Dust, dry grass, chafe can clog your grill and radiator restricting air flow...try using high pressure air and blow from the back forward to clean it out. If it was real bad from years of neglect, I have used a lot of water...but once you get it clean, high pressure air on a regular basis should keep it clean.
Tim A.
Fred Tedescucci
03-06-2005 14:48:49
Thanks Bob... This thing wasn"t really acting like a stuck thermostat, so I sprayed some "cleaner" onto the exterior of the radiator fins & waited a few minutes & hosed it down. Seems to be doing some better now. As I said earlier the temp gage has always been "rock steady" in the middle & it"s somewhat un-nerving to see it go above that. Now let me "pick your brain" about something else: Any thoughts on using a cooling system cleaner on a "wet sleeve" diesel?? Safe or not?... Had thought about taking the radiator off & having it cleaned out, but JD (bless their little pea pickin" hearts) buried the radiator deep inside & it looks like it might be a real job on this tractor. Any thoughts would be sincerely appreciated...
Fred
Bob
03-06-2005 10:08:59
Check for: Loose fan belt (also for badly worn belt and/or pulleys), stuck thermostat, radiator fins clogged with debris, and as a last resort, have the insides of the radiator cleaned at a radiator shop.
rbiemans
03-06-2005 19:24:08
 Re: 2010 overheating in reply to Bob, 03-06-2005 10:08:59
i had the same problem then i found out that the coolant was getting into the engineblock. The coolant level goes down and the oil level goes up . good luck
George Griffith
05-22-2005 11:39:13
 Re: 2010 overheating in reply to rbiemans, 03-06-2005 19:24:08
I have a 2130 and have had similar problems when bush hogging tall, heavy growth with lots of fuzz that gets on the side panels and in the radiator fins. Blowing out cures. However, yesterday, it severely overheated in a short time, and was very low on coolant. When I refilled, it was gone and same problem in less than 30 minutes. Would appear I may have leak into oil. rebiemans ... What did you find with your coolant getting into block?
