4840 wheel weight removal
RonJohnson
03-06-2005 08:15:18
I have a 4840 with 1500 lbs inside rear wheel weights. I want to remove them and put them on another tractor I have. Can anyone tell me the best method for doing this switch? I have experience with moving the wheels in and out on the axle using the pinion gear. But I have never taken one all the way off the axle. I know I need to be careful and do things right with something this heavy. Anybody have any experience with this?
Ron
Tom (Ks)
03-06-2005 15:09:17
 Re: 4840 wheel weight removal in reply to RonJohnson, 03-06-2005 08:15:18
We use wheel carts to remove the complete wheel, then use a fortlift with only one long fork attached to it. Run the long fork in the center hole in the weight and lift up to take pressure off the wheel, then remove the bolts and back out with the weight.
