41 B carb modification
donwisc
03-06-2005 08:09:56
Got another surprise getting into this B.
Sometime in the past the threads were stripped on the stem to bowl connection so someone cut the stem off and welded about a 3/8 inch nut on the end and then used a capscrew to attach the bowl using a series of spring washers and gaskets.
Surprisingly it did not leak and I didnt notice it until I got it home.
Is this going to create a problem or change the performance of the carb? I am waiting on some parts and will see for myself next week when I start it but curious what you guys think.
Duane Larson
03-06-2005 11:06:59
 Re: 41 B carb modification in reply to donwisc, 03-06-2005 08:09:56
donwisc,
As long as the welded nut does not interfere with the idle and load needle holes, and the bolt holding the bowl on does not extend too far up in the neck to restrict fuel flow through the idle and load needles, and the nozzle is still in place (I assume there is not a (good) nozzle spring to hold it in place), and there are no air leaks, it probably will work ok.
However, keep in mind that most old carbs haven't been overhauled recently (had their nozzle and passages cleaned, snug bushing/throttle shaft fit, snug throttle plate fit, non-leaking float/needle/seat, etc.) so may not function properly regardless of repairs to the neck.
donwisc
03-06-2005 18:25:05
 Re: 41 B carb modification in reply to Duane Larson, 03-06-2005 11:06:59
Thanks Duane , that makes me feel better. The nozzles are not interfered with and I am soaking the carb in a gallon of carb/parts cleaner and will clean all passages, and will install a new carb kit. Cant wait to fire the old beast up again.
This one has some nostalgic vaue as this is what I grew up on, and it was the only tractor we had farming between 80 to 100 acres
Duane Larson
03-06-2005 19:12:06
 Re: 41 B carb modification in reply to donwisc, 03-06-2005 18:25:05
donwisc,
I'd say it's worth a try. If there is still some of the threaded area left above the welded nut, and if it turns out to be necessary, a new neck made from the bottom of a Champion W-18 plug can be brazed on.
