How to check transmission oil level?
Kurt_JDB
03-06-2005 05:35:09
How do you check the oil level in the transmission of a "51 B? should it be up to the level of the filler hole? I plan to change the oil if I can ever locate straight 140 weight gear oil, but in the meantime I would like to make sure it is at the right level.
Thanks,
Kurt
JDK
03-06-2005 06:45:25
 Re: How to check transmission oil level? in reply to Kurt_JDB, 03-06-2005 05:35:09
It will hold 4 1/2 gallons (18 quarts), which will take it up to the filler hole.
There is more than one drain plug.
Dave Brennan
03-06-2005 06:13:19
Yes, It should be level with the filler hole. I've used 90/140 from NAPA with no problems. It is suppose to retain the viscosity of 90 in cold weather and 140 in warm weather. I think it holds about 5 to 6 gallons.
