JD 50 electrical system
Daniel Horton
03-05-2005 08:57:52
My 1954 50 has a positive ground. I ordered a electronic ignition conversion kit for it but the only kit I could find for my Delco 1111558 distributor was for a negative ground system. Can I just change the ground to negative and everything else work ok.
brad thomas
03-05-2005 13:19:50
 Re: JD 50 electrical system in reply to Daniel Horton, 03-05-2005 08:57:52
just bought the electronic conversion kit for my 50. ordered it through yesterdays tractor parts. tell them you want part # 1121-p12. hope this helps. brad
buickanddeere
03-05-2005 09:45:19
I bought a positive ground Pertrnics kits for the 50 with the Power-Bloc last year along with the matching 12v 2.8 ohm tractor coil. Opened the plug gap up to 45 thou and she throws one large blue arc. Somebody at the parts counter is just selling you what is in stock. Check the Pertronics site, they just add a -P to the end of the parts number for positive ground.
John T
03-05-2005 09:20:09
Daniel, YES you can change the Battery to Negative ground, AND BE SURE N DO THAT BEFORE YOU WIRE THAT ELEC IGNITION OR ELSE YOU MIGHT FRY IT.
Reverse the battery first,,,,,then you will have to reverse any ammeter leads so it dont read bass ackwards,,,,, ,then polarize the Generator by first dead grounding its Field post and then momentarily flash jump a wire from the Voltage Regulators BAT terminal over to its ARM (or GEN) terminal and you should get a small spark,,,,, ,,then remove the jumper and Field ground.
Wire the elec switch AS ITS DIRECTIONS SAY and I highly recommend to get the most bang for the buck from that elec switch TO COUPLE IT WITH A HIGH ENERGY HIGH PERFORMANCE COIL. Since youre now at Neg ground, the coil (check with elec switch vendor, not what Im guessing at !!!!!) will likely wire with its - lead to the distributors connection stud, while its + lead is what receives power down from the ignition switches IGN hot when ON terminal. (that may also be where the elec switch gets its 12 volt red input power, see below)
Are you at 12 volts???? If so you can use EITHER a full 12 volt rated internally ballasted coil (likely what any high energy after market high performance coil will be) or else a 6 volt coil with an external voltage reducing (12 to 6) ballast resistor. NOTE if you use a 6 volt coil and an external ballast resistor, check with the vendor cuz in that case the elec switches power input (likely red) is wired ahead of the ballast (not to coils input as normal) so it sees 12 instead of the ballasted 6 volts.
PS I suggest with an elec switch and a high energy high voltage coil to run a wider plug gap, maybe in the o.035 to o.o45 or so range, check with vendor.
Clear as mud?? post back any questions n check with the switch vendor (especially to match the switch rating with any high energy coil !!!!! ) good luck n God Bless
John T Nordhoff in Indiana
Bob
03-05-2005 09:13:05
If you are retaining the original generator, I would hesitate to convert the system to (-) ground. Due to differences in the voltage regulator contact material between the upper and lower contact points, SOME voltage regulators have longer life when used with the battery polarity there are designed for.
Have you talked to the technical people at Pertronix to verify that there is not a (+) ground module made for your tractor?
If you need the phone number, go to www.pertronix.com and the tech help number is on the website. They are great people to talk to.
However, if there is no (+) ground alternative module, and you polarize the generator to the new polarity MOST LIKELY it will work OK.
