1938 head studs washers
marty Z
03-04-2005 22:34:18
Just got my gasket kit from Deere and the head stud washers are copper now. Are they OK to use or should I go get some lead ones like I have always used. Wonder if the copper ones seal like the lead ones ?
Thanks
Marty Z Curtice Ohio
730-LP
03-05-2005 18:37:40
 Re: 1938 head studs washers in reply to marty Z, 03-04-2005 22:34:18
The lead or copper washers are NOT intended to seal out water around the head bolt.They are used to make smooth surface under the nut so that the nut don't cut into the head and give you a false torque reading. To seal out the water put a good sealant around the head bolts [make sure to put the FLAT end of the stud in the block] before putting them in the head.
Aaron S
03-05-2005 07:11:55
Marty, I just rebuilt a 39 AR with the copper washers and now I have water getting in the oil somewhere. Although I don"t think it is the head studs I will say I don"t like the copper washers as much as I did the lead. They just seem to hard to make a good seal like the lead washers. I agree if you can get the lead washers, use the lead washers. After all how many years have they worked just fine in the 2 cylinders?. Hope this helps.
Aaron
Mike M
03-05-2005 16:36:46
 Re: 1938 head studs washers in reply to Aaron S, 03-05-2005 07:11:55
I would pull off your valve cover and take a real close look at those push rod tubes as a source for your water leak.
Mike M
03-05-2005 04:58:50
I have only done one head since those copper washers came out. This was on a 720 D that is having head sealing troubles as it is. I went ahead and used them ,but I don't like them. They don't squish down right,too hard,don't seem to squash evenly and had a chunk bust out of one of them. If you can get ahold of some lead ones use them instead.Next time I'm going to think about using steel ones or nothing at all with some kinda goop on the nuts ? If you find a good substiute post back on here. I'm not a big fan of the copper idea so far.
Marty Z
03-04-2005 22:36:13
Forgot to mention ---It's an AR
D-GEEK
03-08-2005 17:50:52
 Re: 1938 head studs washers in reply to Marty Z, 03-04-2005 22:36:13
I just bought lead washers for my 35D from Bader
John Deere in St. Louis MI. I did not specify
either as this is my first resto, but I just automatically got lead. They were in a modern
looking package and were sold separately from
my gaskets. Call Fred at Bader's, he'll hook
you up. 989.681.5771 Good Luck! D-GEEK
Marty Z
03-08-2005 22:27:30
 Re: 1938 head studs washers in reply to D-GEEK, 03-08-2005 17:50:52
OK ,,, here is what I'm gaonna do. I'm going to get some lead washers and seal the studs. Hope this takes care of any problems. I'm also gonna expand the push rod tubes at the 2 outer surfaces with a punch again. Also gonna use Permatex #3 on the head gasket like clooney said. Didn't have problems before the rebuild and don't want any after. Hope I covered all the bases. Thanks guys
Marty Z
