No serial tag 2010
B KING
03-04-2005 20:54:50
Is there any other way to determine what model year my 2010 is without a serial tag.
jdemaris
03-05-2005 19:46:21
 Re: No serial tag 2010 in reply to B KING , 03-04-2005 20:54:50
You can narrow it down quite a bit by identifying certain parts on the tractor and engine. Easiest way to it would be if you have a parts book. 1010s and 2010s went through many changes as they evolved. Early ones had different engine bearings than later. Gear shifters got moved. If diesel, injector design along with injection pumps changed over the years. With gas engines, the governor changed design many times. This parts differences with give you a serial number range for the tractor.
RHA
03-05-2005 09:04:35
? I am assuming that you know the only serial number is the tag on the right side of the engine block.
BKing
03-05-2005 12:37:59
 Re: No serial tag 2010 in reply to RHA, 03-05-2005 09:04:35
Yes. I think what happened was the last owner of the tractor overhauled the motor. In the process he had the motor hot tanked. The serial tag has either been misplaced or disolved in the hot tank process. I think what I will do is try to locate the original owner. He is supposed to live in my area. Thanks
