420 popped in transaxle now won't move and won't g
denjoe
03-04-2005 15:22:19
What is up with this? I was pulling gravel with my 420 in 1st. Good sized load. I heard a pop in the transaxle. Now unless I put the clutch in (it still works fine) it dies as if it were in 5th gear on a hill. Shifter moves to all positions but no matter where I put it the tractor doesn't move an inch. What broke in there?? Thanx!
buickanddeere
03-04-2005 19:01:18
 Re: 420 popped in transaxle now won't move and won in reply to denjoe, 03-04-2005 15:22:19
No tractor was made to lug it's guts out under max load in 1st gear where the tires have little to no slippage. A 420/430/435/440 is into that HP area where abuse combined with old trans lube mixed with water. Can wear the model M and 40 sized ring and pinion out prematurely. The good news Mother Deere has a fix. The early 1010 up to serial number 31,000 used a very beefy R&P that will bolt right into a 420 slant steer and later tractor. While digging around 1010's. You can slow your two cylinder Dubuque 15% in every gear by swapping in the post 31,000 final drive gears. When finished fill the trans with Amsoil series 2000 racing oil. It won't squeeze out from between the gears and let metal touch metal. For now, pull the three bolt cover off the back of the trans just above the pto shaft. Get a good flashlight, a box of Kleenexes,concentrate, take a deep breath and look in.
CPeter
03-04-2005 16:42:14
My guess is that you probably don't want to know. Seeing as to how that I have a 420, I will be interested is finding what you broke. Keep us posted.
CPeter
denjoe
03-04-2005 15:23:56
Yes, the pto still works fine.
