630 muffler bolts
Rick in IA.
03-04-2005 14:21:05
I just got done pulling apart the 4 studs and the spacer under the muffler on my 630. The muffler had been welded on to the spacer as the studs were broke and rusted. I thought it would be a fun way to spend a day off. It took most of the day, 2 of the studs came out the other 2 had to be drilled out and tapped. Called my local JD dealership and they had the new studs, brass nuts and washers in stock! As the spacer was buggerd up from being welded I plan on turning it upside down and reusing it, along with lots of never sieze. Very satisfing day! This project was kind of like rebulding the float ride seat, once you do 1 your an expert ! Thanks for all the good information on this site.
Rick
CLW
03-04-2005 20:14:06
 Re: 630 muffler bolts in reply to Rick in IA., 03-04-2005 14:21:05
Rick, if you are like me and don't do another one for a year, you have to learn all over again.
CLW
