720 Row Crop D
Greg Haddox
03-04-2005 12:26:27
Hey there,
I've just jumped into that wonderful world of Antique Tractors, and I'm wondering how far over my head I am. The tractor, I just sent the money out for today is a 720 D, that runs well but the dealer didn't get a battery to check the pony motor. So I'll just imagine the worst case, and assume the poney doen't work. How big of pains are these pony motors, and are parts still available, and if it is trashed would electric start conversion be cheeper than an overhaul. Any thought are appreciated
freddy
03-04-2005 20:06:10
 Re: 720 Row Crop D in reply to Greg Haddox, 03-04-2005 12:26:27
Congrats on the 720D. I bought one and have been working on it for over a month now. Started with the its ready for the field speech followed closely by the screeching pony trans during starting totally out of oil oops. Look it over good when you get it home. Mine also was low in the trans oil. sludgey black oil in the first reduction drive. Took it all apart changed all bearing for good luck, amazingly still in great shape, Outer bearing ruff. Powershaft bearing loose. Easy to tighten them. Keep in touch I would like to see what you find in yours.
Soldier Tom
03-04-2005 17:30:42
I have one too. The pony was shot, but still ran kinda good. We found a pony that ran like a top for 650 bucks, they are out there, lots of people are taking the ponys off and putting lectric start on their pulling tractors to save weight or something. Anyway, the motors are fairly straight forward.
There are some interesting strings on this site if you do a search, one on pulling a diesel to start it, and several on the pony motors come to mind. I really like mine, I bet you will too. Where are you located? Mine started out in Lamar MO and is in Eastern Tenn, via Ohio, Nebraska, and somewhere in South Dakota. ~Walk in peace~
Soldier Tom
Emerald70D
03-04-2005 15:25:21
Greg...you may be ok, but normally the pony engine will need new coils/points/ condensors/plug wires (~200 dollars). If it does not have any internal broken parts, it will run but probably smoke at high rpms. If it has broken internals, get the checkbook ready. Parts are available but expensive. Pretty easy to spend 1000 dollars in that little engine. Electric conversion detracts from the value of the tractor somewhat and will cost about 800+ dollars if you do it right.
