How much does an R weigh?
Bguy
03-04-2005 11:07:29
I have an R to move and my trailer is a 20" gooseneck with 2 6K axles. The trailer and tires are in very good condition. Based on what I have been able to find out, an R weighs about 7100 pounds, is that right? The tractor has no weights, fluids in tires or etc. If 7100 pounds is about right then this trailer should be able to handle it behind my 3/4 ton P/U. Anybody have any experience with this?
Tony W
03-05-2005 08:06:13
 Re: How much does an R weigh? in reply to Bguy, 03-04-2005 11:07:29
I thought I would put in my .02$ I put mine across the scales and it was 10,400lbs. Pull it with 1ton 350 stroker and 21,lbs trailer. Just my input. Be safe!
jbul
03-04-2005 18:51:36
Pulled my R with a 86 ford 3/4 6 inline. 24' goose 1400 lb rated. just fine till I got caugh be the DOT. Tractor weighed as high as 9100 lbs weighted for pulling. should weigh around 7200 lbs dry.
Big_Roy
03-04-2005 17:18:31
My 51 weighs 8850# with fluid in the tires but no other weights.
when I bought it I pulled it home with a 3/4T Chevy with a 6.2 diesel and a trailer similar to yours without any problems.
Just wish I wouldn't have had that 3" dual exhaust on the truck though!
Kent W
03-04-2005 12:21:09
Ran my R over the scales during a local tractor pull, and found it to be just short of 7,800 lbs.
With out weights or fuilds in tires and ajusted without me in the seat.
Paul from MN
03-04-2005 11:45:56
You are pretty close on the weight. A R as you described it should weight about 7400#. Your trailer should not have a problem with it.
If the truck is up to it is dependant on the engine. I think any 3/4 ton should be able to pull it a short distance. If you have a diesel or the larger gas engine it should be no trouble.
