1020 gas Hydraulic pumps
seeing green
03-04-2005 09:32:43
Hello, I have a John Deere 1020 gas burner with a Hydraulic pump leaking pretty badly. The tractor does not have power steering or a loader. I"m trying to decide if I should rebuild or replace the pump? I am told there are after market pumps availible to save a few hundred bucks. What do you guys recommend? Is there other size pumps I should consider if I want to add a loader down the road? Any thoughts or suggestions are welcome.Thanks,Steve
jdemaris
03-04-2005 17:23:26
 Re: 1020 gas Hydraulic pumps in reply to seeing green, 03-04-2005 09:32:43
The .69 pump is the same as the 1.38 with four pistons left out of it. They are both pretty small for loader use. You can put the more traditional and larger Deere pump on it. Any Deere tractor we sold, new or used, if it was getting a loader lost that little pump . If you ordered a 1020 through Deere Industrial instead of Ag. (then called a 300), it could be bought new with the 2.4 full-size pump on it, just like the 2520s, 3020s, etc. used. Just have to change the pump drive to make it fit. If you don't care about pump capacity,that's a fairly easy pump to work on. It does NOT have adjustable bearings like the bigger Deere pumps. Just needle bearings. So, as long as the shaft is okay, all you need is a gasket kit and quad-ring.
jeff 2030
03-04-2005 13:35:56
you didnt state if all the hydraulic functions are or are not working.if you only have a leak that most likely is the shaft seal & packing ,simple and not very expensive to replace
John36bn
03-04-2005 13:20:32
If you mite put a loader on it go with the big pump. I`d also go with a new pump if the hydraulic system has been maintained not abused. No sense putting a new fresh pump on a system that mite be polluted with crud.
1020gas
03-04-2005 10:19:50
Those pumps came in two sizes. Four piston 0.69 cu. inch and eight piston 1.38 cu. inch. They look identical on the outside
