1020 selective control valve
deereford
03-03-2005 20:47:33
Will a selective control valve assembly from a 1020 hydraulic system function with a gear pump open center system? I will appreciate greatly any advice. Thank you very much! deereford
jdemaris
03-04-2005 05:49:31
 Re: 1020 selective control valve in reply to deereford, 03-03-2005 20:47:33
Deere does use some valves that are "convertible", i.e. you change one plug to use with either open-center or closed-center. That is NOT the case though, with the selective control valve on the 1020.
Tx Jim
03-04-2005 03:44:28
Deereford,closed center valve is designed to stop oil at valve.This stoppage of oil could split gear pump.What machine are you wanting to put this valve on?I would sell valve and buy correct one.Tx Jim
