2840 leak
tomtractor
03-03-2005 16:09:45
I have a leak on my 2840 from the shaft that supports the 3point swing arms.This shaft goes through the bottom of the trans. I have replaced the seals and bushings but it only lasted about 10 months before it started leaking real bad again. Do I need to rip the rear end of the tractor apart to replace the shaft, or does anyone have a better idea.
donmyeil
03-04-2005 08:17:33
 Re: 2840 leak in reply to tomtractor, 03-03-2005 16:09:45
You were almost there when you replaced the seals and bushings. Just remove both sides and pull the shaft. Always replace the shaft if it is over a year old unless you want to do it again. The seal area rust's and pits so the seals wont hold. Also shim the ends of the shaft as tight as possible to take away any end play. Large bales are the death of these seals and bushings.
