First Reduction Gear
New to Green (F
03-03-2005 14:58:20
On your post you said you had trouble with a bearing on your first reduction gear. What I would like to know how you knew you had a problem.
Year and make of your tractor. I have a '52' B
and would like to make sure I don't run into this problem.
Thanks
Walt in Jaxn Tn.
03-05-2005 07:58:27
 Re: First Reduction Gear in reply to New to Green (Freddy), 03-03-2005 14:58:20
First reduction gear problems seem to be common in "A"s, "B"s and I guess "G"s too. The outer bearing in the little cast iron hub behind the clutch pulley gets out of alignment because the hole the bearing race is in gets worn (battered mabey?) and the whole bearing slips back and changes the angle of the shaft the first reduction gear (it's a big gear) is on and the angle the gear meshes with the clutch gear (not straight anymore) and,, and,,more yet! The angle the first reduction gear shaft with the input shaft. The first reduction gear shaft is short and fits in a set of bearings (cage bearings, kind of). I believe this is where the high/low range operates. I've really confused you now, I've confused myself! Anyway, if that shaft gets out of alighnment it sings wirring noises. Hope I've been a help more than a hinderance. --Walt--
