G flat head?
steve usa
03-02-2005 18:40:56
I know what a flat head ford is but not on a G
buickanddeere
03-03-2005 13:41:08
 Re: G flat head? in reply to steve usa, 03-02-2005 18:40:56
If making serious HP with the flat head. The combustion chamber has to be "pinned" for support. Otherwise the higher than stock cylinder pressure will crack the comustion chamber into the water jacket behind it.
DW
03-02-2005 22:38:58
Are you interested in buying a "G" "flat" head? If you are, e-mail me and let me know where you are. Maybe we can work something out. I'm in NW Iowa.
730-LP
03-02-2005 21:07:08
A styled G has a 11.5 inch long block and a 6 inch thick head with the valves recessed an inch into the head and an eyebrow to give the air and gas a swirl.The unstyled block is 12.5 inches long and the head is 5 inches thick and the valves are flush with the head[as Will stated] both engines are rated at 38hp and will make 50hp at 110 to 120 lbs comp with a set of M&W styled pistons running gas.Put a flat head on a short block with M&W style pistons and it will make 70hp at 190 lbs comp.
Dave in Mich
03-03-2005 08:59:10
 Re: G flat head? in reply to 730-LP, 03-02-2005 21:07:08
To run the flat head with a styled short block and get that compression are the M&W styled pistons flat or domed? I've been told that using the domed (high compression) M&W's will blow the head gasket.
Will P
03-02-2005 20:28:41
The flat head G is just that. The valves in the head is totally flat with the head mating surface. All of the combustion chamber is in the block. Anstyled G"s are flat heads.
Now, when she got styled. Deere recessed the valves in the head and put some contouring in the combustion chamber. Now the pistons have to be taller to take up some of the space in the block the the head has gained. But, you put a "flat head" on a styled G and you have LOTS of compression. Flat heads are loved by tractor pullers for that reason.
Will P
F-I-T
03-02-2005 20:03:05
Steve:
I think when they use the term "flat head" on a "G" which we both know is an over-head valve engine, they mean they have planed it so much that it is virtually flat. That's my take, unless they're talking about something like a Heisler head that had reduced valve seat depressions and so raised the compression somewhat.
I'm sure some who's not guessing will stop by and help you out with a proper answer.
Frank
