4010 camshaft difference
hogman_2002
03-02-2005 15:35:18
I was wondering what is the difference in 4010 (diesel) stock cams? I know one has 15 teeth and the other has 20 teeth? If using one or the other is there any change in the timing of the injection pump. Also is there any way to tell which one your block came with? I'm having trouble setting the timing on my injection pump. If I put the oil pump in correctly, I can only set the inj. pump 7 degrees BTC. I can't turn pump anymore because there is no more room in the slot.
maddog
03-03-2005 06:27:52
 Re: 4010 camshaft difference in reply to hogman_2002, 03-02-2005 15:35:18
Hay hogman, call me and I think I can help you out. It can be a little confusing, and this takes a little talking through. AL 231-757-0064
