A Model plate on bottom of case
Dave in SV
03-02-2005 13:48:39
I want to fix a minor oil leak. It appears to be coming from a plate on the bottom of the main case. This plate is in the forward left-hand corner, and is across from the oil filter cap. The plate I am refering to has another plate stacked/bolted on top of it.
Am I making any sense?!?!?!? What is that plate for? I need to know so that I can get a new gasket, and I can't seem to find it in the parts catalog
F-I-T
03-02-2005 14:51:31
 Re: A Model plate on bottom of case in reply to Dave in SV, 03-02-2005 13:48:39
Dave:
I believe that is the outer/lower plate of the oil pump. If you remove it, the gears may fall out, or if the drive shaft comes on out, it might lose its connection with the oil pump drive shaft, necessitating removal of the top cover to get them re-aligned.
Proceed with care and caution.
Frank
Dave in SV
03-03-2005 03:40:27
 Re: A Model plate on bottom of case in reply to F-I-T, 03-02-2005 14:51:31
By golly, I think you hit a bullseye! I had been staring at the diagram all along and didn't even know it.
I believe your suggestion of proceeding with care and caution is a good one.
I will do just that!
Thanks for the help.
