8850 vs 8650 drivetrain?
leon
03-02-2005 10:20:50
How was the 8850 4WD tractor drivetrain changed from the 8650 to enable it to live with the 80 additional engine hp of the 8850? Both were rated at 2100 rpm.
Tech 7
03-03-2005 17:51:21
 Re: 8850 vs 8650 drivetrain? Hello Leon in reply to leon, 03-02-2005 10:20:50
Did you have a role in the designing of these tractors Leon? I believe that there were less than 6 of these tractors shipped into Ontario as new machines. As a result there are quite a number of people that had never seen one let alone knew they existed. Our dealership has one in its AOR and I had the opportunity to work on it a number of years back....the injection pump failed,of course this happened in the far back end of a rented farm....it was rather handy as I had no one to distract me as I reviewed the procedure to R&R the pump... BIG tractor...HUGE injection pump.
leon
03-03-2005 18:43:02
 Re: 8850 vs 8650 drivetrain? Hello Leon in reply to Tech 7, 03-03-2005 17:51:21
Did I have a role in designing these tractors? Well, no. I was in other areas of Deere when these tractors were designed, but know the guys who did the designs and as retirees, many of us have breakfast together once a week. After most of a lifetime of working together, you get pretty close.
That big old V8 could have developed into a good engine with time, but it was just too costly and was killed before it got a chance to grow up. The anticipated production volume just never developed. I had a hand in applying a couple of then in a 100 ft. sightseeing boat. They were sea water intercooled and set at 550 hp each as I recall! Want to water ski?
Jake Winn
03-03-2005 10:25:13
 Re: 8850 vs 8650 drivetrain? in reply to leon, 03-02-2005 10:20:50
the 8850 had a double planetary setup on the final drives. This made it so that the transmission did not have to be signifigantly heavier than the 8650. There was also a spacer between the trans case and the drop box to give it a longer wheelbase. These drivetrains were pretty tough. I have been through 2 8850 transmissions. This tractor has been turned up qute a bit. It pegged our pto dyno at 400 hp and was still going strong.
leon
03-03-2005 11:57:15
 Re: 8850 vs 8650 drivetrain? in reply to Jake Winn, 03-03-2005 10:25:13
Thanks Jake, I believe you're dead right.
Well, see, one guy in the bunch of JD retirees sitting around breakfast in Waterloo Wednesday morning volunteered to write up a bit of history for an upcoming Product Engineering Center open house anniversary but none of us could come up with the answer for this question from memory so I volunteered to inquire on the forum.
I looked at the JD Parts site, but it was going to take more time than I had interest. I set the original inquirer at digging in this approach. After your input, the parts site seems to bear you out.
This isn't the first time that a customer has helped the engineers.
leon
Bob
03-02-2005 16:29:15
I believe there is very little (if any) interchange of powertrain parts between the 8650 and the 8850. About everything on the "88" was bigger and heavier.
