4020D oil leak
Ted K/MN
03-01-2005 18:40:34
I see a few drops of oil dripping to the ground directly under the clutch housing on my early 4020D.I took the cover off the bottom and there is some oil on the walls of the housing but the flywheel and clutch assembly look clean. Neither the PTO or tranny clutch slip so I presume they are oil-free. Should I assume the leak is from the rear main seal or are there other places oil could leak and get into the clutch housing? I know the valve tappet cover is leaking some as there is oil down both sides of the engine at the rear, could oil from there get into the clutch housing? I will fix that ASAP but I don't know if I'll have the time to tear into splitting the tractor this Spring to replace the rear seal. Will running it this way over the summer harm anything? It'll only get 75-100 hours put on this summer, mostly light work. Thanks.
Ted K.
msb
03-01-2005 19:12:52
 Re: 4020D oil leak in reply to Ted K/MN, 03-01-2005 18:40:34
Is the oil black? if so it is the rear main seal.If you are only going to use it like you say,I would wait till August when you have more time to replace the seal.
Ted K/MN
03-02-2005 07:00:11
 Re: 4020D oil leak in reply to msb, 03-01-2005 19:12:52
Yep, it's black. Thanks for the input.
Bob
03-02-2005 07:47:34
 Re: 4020D oil leak in reply to Ted K/MN, 03-02-2005 07:00:11
I agree it's most likely engine oil, however, there is an odd seal between the transmission input shaft and the PTO shaft that can leak, also. Usually even the more clear hydraulic oil will drip out of the clutch housing black after being flung around, and mixing with dirt and clutch debris in the clutch housing, so replace that seal, also, while it's split.
There's another seal, farther back, on the PTO shaft. Replacement of that one requires a split between the transmission and clutch housing, so hopefully that one isn't leaking!
Ted K/MN
03-03-2005 06:57:21
 Re: 4020D oil leak in reply to Bob, 03-02-2005 07:47:34
Thanks guys, it is engine oil since the hydraulics rarely need any added fluid. The crankcase oil goes down only slightly and only after many hours, but the leak will need attending to. TK
Jake Winn
03-03-2005 10:28:43
 Re: 4020D oil leak in reply to Ted K/MN, 03-03-2005 06:57:21
There is one more place that oil can leak. It got me on a 4000 once. There are two operating pins that push on the pto clutch bearing housing. One on each side of the input shaft. They are sealed with an oring and a backup ring. The ones on this tractor were worn and the orings cut. Might change them while you are there for safe measures.
