4020 Hyd. control conversion??
Derek Maney
03-01-2005 14:21:48
I am looking at a mid 60's 4020 that has a new motor, clutches and the tranny has beed gone through completly. I want this tractor for field work and runnin my hydra swing haybine. I was wonderin if I got ahold of used parts if I could switch it over to a console... Trying to run a hydra swing with the hyd. contols on the dash is nothing short of miserable. Any imput would be greatly appriciated.
Nathan (SD)
03-03-2005 07:11:51
 Re: 4020 Hyd. control conversion?? in reply to Derek Maney, 03-01-2005 14:21:48
I use a Hesston 1014 on a 4020 and a 830 Case. I actually prefer the dash mounted levers for the job. 830 Case has levers to the right of seat. I use the tall lever to swing and the short one for lift. Push lever for left, pull lever for right. I would try it first then if you don't like it you can rig up something else.
JD Jack
03-01-2005 18:43:32
another option if you don't like the messy look of spool valves on the fender is to add a joystick valve from a loader, and put the plug ins and actual valve someplace on the back. To do this, you would tee into the pressure line by the brake pedals(there is a elbow there now), and return oil to the filter cover. You can get a filter cover off a 2640(I think) with a plug in for a hose. A neighbor recently did that when his dual valves(under the hood -old style) went bad.
LJL
03-01-2005 15:57:52
YOU CAN ALWAYS MOUNT AN AUX TYPE VALVE BETWEEN SEAT AN FENDER IF YOU WANT RIGHT HAND HYD CONTROL ONE OR TWO SPOOL AND PUMB INTO THE HYD SYSTEM JUST AS YOU WOULD DO WITH A LOADER VALVE JUST MAKE SHURE USE A VALVE SETUP FOR A CLOSED CENTER SYSTEM IHAVE DONE THIS AND IT IS COST EFFECTIVE AND WORKS FINE LJL
R. John Johnson
03-01-2005 15:57:35
Derek
There may be an easier fix to your problem. If looks are not all that important to you, you could add a valve on the fender. Plumb it in like you would for a loader, but put pioneer couplers on the back. The valve must be closed center. Lots of info in the archives on setting up a auxillary valve like that.
one other option that you might consider is to add control levers on the right side and use push pull cables to run the existing valves. This would take some work and might not be pretty, but I'm throwing out ideas here.
My $.02
John
msb
03-01-2005 14:39:13
Not saying it can't be done.Some people seem to be able to do about anything but I would never attempt it.The cost would be prohibitive.Are you sure the dash mounted levers would be that hard to use.I have both kinds and I prefer the dash levers,by far.I never did like constantly bumping my knee on that darned console anyway.
Henry Dreyfus was a genius and he was the one who disigned the operstor's station on the new generation tractors and he put a lot of thought,study and planning into the design concerning operator convenience,natural human movement and comfort.Deere only went to the side console to standardize the operators station to match what other manufacturers were doing at the time.If you are dead set on a side console model then I would look for a tractor with one.
Henry Dreyfus was also the one who came up with what is now called the international symbols.i.e. gas pump,oil can, water temperature,lightning bolt,turtle & hare,etc.(probably more information that you wanted to know)
thurlow
03-02-2005 08:57:34
 Re: 4020 Hyd. control conversion?? in reply to msb, 03-01-2005 14:39:13
I'm with you; have never understood the bias against the dash mounted levers; anyone with any "serious" tractor time has learned to sit 'bout half-way cross ways in the seat so as to watch drawn or rear mounted implements. This puts your left hand in position to operate levers. My Dad used to say about those who sat facing forward without ever looking back that they weren't driving the tractor, they were just herding it down thru the field.
