Deere 3020 engine rebuild
BJINTN
03-01-2005 14:13:21
My 3020 is at the JD dealer's shop and they told me the engine needs to be rebuilt due to diesel fuel leaking into the oil (due to a failed fuel pump) and it damaging the engine. They have quoted me a ballpark figure of $5,500 to rebuild the engine - is this a reasonable price?
Thanks.
BJINTN
03-08-2005 07:59:06
 Re: Deere 3020 engine rebuild in reply to BJINTN, 03-01-2005 14:13:21
An update on my JD 3020 rebuild for those of you who are interested (BTW - thanks for your inputs, they have been very helpful). I met with the JD service folks yesterday and they showed me the damaged crank shaft, bearings and other parts (they were able to pull mud out of the engine block - they seemed to think someone had been using pond water for the radiator). The tractor is in serious need of repair and I have given them the go ahead.
In addition to the engine rebuild I have authorized replacing/fixing the clutch, the radiator, the generator, and other smaller misc. items. The bill is now up to $8,000. I don't anticipate it will go much higher and may even come in under the original estimate (yeah right!)
When it is all said and done I'll have a very expensive '68 3020 that will hopefully run a very very long time.
buickanddeere
03-03-2005 14:08:23
Have a look at the main and rod bearings. If they are not "wiped". Tell the dealer to find some other sucker to rip off. As previously stated that sounds like $10,000+ job by the time they finish cleaning out your bank account. When completed you still have an old tractor. At that price the money would be far better spent on a new JD 6403 which starts at $27,000. Or a JD 6215/6415 .
Rodney A. Johnson
03-03-2005 10:35:50
I had 3010D rebuilt few years back. Parts, block work and head work were 3800 (JD parts)...I paid no labor as cousin was learning diesel mechanics and needed a project to work on.
I'd check with your dealer, I highly doubt the quoted price included labor...if so, question how much they are fixing
Jason(ma)
03-02-2005 20:03:43
have you looked into buying a short block from JD? It USED to be if you had to touch the crank it would be cheaper to replace rather than rebuild, not sure now.
Jd Jack
03-01-2005 18:52:45
What type of rebuild are they going to do? What are they going to replace? A complete rebuild will definately cost you more than that. I am guessing that they are skipping some parts, or assuming that they are not bad. I did a complete rebuild of my 3020 for $ 7200, and a 4020 for $6300. Price depends on whats bad and good... head work? cam? crank? oil pump? bearings and seals? balancer?.... These were done by a local mechanic and machine shop that charge much less than a JD dealer will for labor. Check into what you are getting and post back!
Redgreen Man
03-01-2005 14:57:49
Cost me $5150 a year ago to do my '71 3020 Diesel.
BJINTN
03-01-2005 15:41:51
 Re: Deere 3020 engine rebuild in reply to Redgreen Man, 03-01-2005 14:57:49
Thanks for your information. At least I know they are in the ballpark. That makes me feel better!
Jim in AK
03-01-2005 22:55:38
 Re: Deere 3020 engine rebuild in reply to BJINTN, 03-01-2005 15:41:51
Buyer beware: I gave the go ahead ot rebuild my 4010 D @ $4,000.00 but I got a finel bill @ just under $10,000.00. Only to find out that he put the cluch disk in backwards and that broke the trany/dif. housing. Another $4,000.00 to fix that. I now have so much money in this 4010 I painted the dash "GOLD".
Jim in AK
donmyeil
03-02-2005 07:30:20
 Re: Deere 3020 engine rebuild in reply to Jim in AK, 03-01-2005 22:55:38
You paid top shop rates for a qualified tech.If he broke the trans because of stupidity The dealer owes you $4000 or at least a reduced cost. Everyone makes mistakes once in awhile but the customer shouldnt have to pay. Thats what you expect for unqualified help but you payed for a certified teck. I was a teck for 40 years.
ebbsspeed
03-02-2005 07:12:23
"he put the cluch disk in backwards and that broke the trany/dif. housing. Another $4,000.00 to fix that"
Was this $4000 in addition to the $10K? Hope you didn't pay for his mistake!
Mike M
03-02-2005 05:11:22
If someone quoted me $4000 and then charged me $10,000 without farther approval,I'd left it set and they'd own it.
