Cityslicker
Dan
02-17-2004 19:04:44
I have a 2520 J. D. and want to purchase a plow for this tractor. How many bottoms will this tractor pull? And is a 3-point hookup what I should be looking for? I am not sure what cat. this tractor is cat. 1 cat.2 etc---The tractor has a gas engine. Where do I look and what do I ask for? As you can tell I know very little about farming. I want to plow about 3 acres. I am retired and need something to play with. Any advice would sure help-- Thanks Dan
jared
02-18-2004 17:02:52
 Re: Cityslicker in reply to Dan, 02-17-2004 19:04:44
My dad bought a f145 plow this fall/winter, for our 2520, they are hard to find in this area, so go luck. also, the 252o has pleny of power to pull a 3 bottem plow. you may need to add a set of tire chians to get extra traction though.
MIKE HANLEY
02-17-2004 20:04:04
Plows are pretty cheep around here. I don't know any of the big guys around here plowing any more. It's no-till or the "soil-saver" style chisel plows. We parked our 3-16" semi mount plow in 1985. Course we now have a law in the State of Wisconsin that you have to have a tillage plan on file and must have a fertilizer plan also on file. Tillage plan must hold soil loses to less then a 3T loss factor and all soil must be tested and only so much ferilizer put on per acre. If you put on manure, you must have EVERY load of manure tested for fertilizer content. This mkust be done by a licenced pro. The farmer can't do it himself. The Federal EPA is looking at Wisconsin's law as a model for a national federal law. Because the law was written so Wisconsin could meet the Federal law under the clean water act, the EPA is taking a good hard look at it. Loop hole in the law is that it can't be enforced without costsharing and the state is Broke. There is NO small acreage that is exempt from the law. Something to think about if it becomes a federal law. So the first question to ask yourself is do I need to plow? What are I plowing down? Will a disc or digger work up a seed bed for what you want to plant. If you still feel the need to plow, your tractor would easly handle 3-16". Eather a 3 PT or a semi mounted plow. An F145 semi mount or an F45 3 Pt plow. And That would plow your acreage in about 2 hours. Your tractor has CAT II 3 PT.
