Block Sleeving
Wes in Texas
03-01-2005 07:01:36
I am looking at sleeving a block for an unstyled A and was wondering what luck or problems people have been having with a sleeved block.
430WLPG
03-01-2005 17:44:18
 Re: Block Sleeving in reply to Wes in Texas, 03-01-2005 07:01:36
Where in Texas are you? There's a place in Wichita Falls that can do it.
Wes in Texas
03-02-2005 05:34:23
 Re: Block Sleeving in reply to 430WLPG, 03-01-2005 17:44:18
I am in Waxahachie, just south of Dallas. Do you have the name and number for this shop?
Gpower
03-02-2005 08:45:24
 Re: Block Sleeving in reply to Wes in Texas, 03-02-2005 05:34:23
Trinity Casting...Dallas Texas
Mike M
03-01-2005 11:14:38
I agree with Earl. Make sure the sleeve goes all the way through with NO STEP. I have even had blocks that had chunks broken out of the bottom from a valve dropping and bending the rod sleeved and they worked fine.
Earl S.
03-01-2005 07:51:56
Sleeve the block all the way through. Do not leave step at btm of sleeve to press sleeve to.Reason ,btm ring will catch. If machinist thinks he wants to secure the sleeve, drill sleeve skirt and secure with cast iron crack repair tapered pins before the finish bore and hone. Find shop that has done Deere sleeving. Sleeves are avaiable from LA Sleeve, California.Email if you have questions.Earl In Illinois
