AM452T PINION GAUGE
HAL
03-01-2005 06:26:17
I am trying to set the depth on my pinion shaft on my 420t and was curious if anyone had a AM452T gauge that you could give me some dimensions from mainly what diameter the round stock is that sits in the bearing quill and is the 2.782 inches measured from the center of this shaft,if it measures from the center i dont guess the actual diameter of the round stock will matter,also does this shaft rest in the bearing quill or do you remove the bearing quill and mount it in the case where the bearing quill mounts up? I have access to a machine shop but just wanted to understand in my mind what i am building, my manual doesnt show a good picture of it if anyone could post a picture that would be very helpful. Thanks Hal
