Installing a live PTO pump on '52 B
PeteNY
02-28-2005 15:43:46
Guys, We obtained a live PTO pump and plan on installing it on our '52 B, I have seen another one and know where the plumbing goes, but I have no idea if I need to do anything internally...when we installed one on our Super H Farmall, we had to disconnect the stub that drove the original. Also anyone that might have a service booklet for thesw pumps I'd be happy to pay for copying and shipping, or point me to a company that might have this info available. Thanks Pete
PeteNY
02-28-2005 19:20:20
 Re: Installing a live PTO pump on '52 B in reply to PeteNY, 02-28-2005 15:43:46
Thanks guys...I will get on ordering the service bulletin, I still have the donor tractor, so I should be able to get the blocking plate from it. I assume that the blocking plate should work on both (the donor is a '50 and the '52 has the slightly different valve housing like the 50's got)...yup I have the drive key...thanks again, very helpful. Pete
Nathan (SD)
03-02-2005 07:27:26
 Re: Installing a live PTO pump on '52 B in reply to PeteNY, 02-28-2005 19:20:20
faster to make a new plate than take old tractor apart.
Jake
03-02-2005 17:06:35
 Re: Installing a live PTO pump on '52 B in reply to Nathan (SD), 03-02-2005 07:27:26
Have you ever actually tried to make one of those plates? They are 16 gauge steel (1/16" thick).
There is a guy who makes excellent reproduction block-off plates. I hear he now also reproduces the suction fitting that goes in the drain hole of the Power-Trol sump.
JPatton
02-28-2005 19:01:23
You need to give the folks at Green Magazine a call. Ask for service bulletin #198. It is a reprint from Deere. Cost is $3.00. The phone number is 402-643-6269. Like stated below, you need to remove the idler gear from the PTO drive. You will need a block off plate and gaskets. I hope you got the drive key with the pump. They are not hard to build but you need to see one first.
Good luck
J
JPatton
02-28-2005 19:19:27
 Re: Installing a live PTO pump on '52 B in reply to JPatton, 02-28-2005 19:01:23
You will also need a special fitting from the tractor you got the pump from. It goes in the powertrol. There is a guy selling complete kits on Ebay from time to time. I bought some stuff from him a a swap meet. He can fix you up with the fitting , drive key or plate or anything else you need. Unfortunately, I can't find his card at this time. Keep watching ebay for John Deere hydraulic pumps.
Good luck J
ET
02-28-2005 17:15:50
You need to remove the idler gear out of the pto pump and install the blocking plate for the preasure passage between the rockshaft housing and the powertrol valve housing.
