Ron, the "best paint" wouldn't be either Deere green or TSC or equivalent paint.. ~I can't tell you the best as I haven't tried them all but the automotive Acrylic Enamels or Urethanes are much better at being scratch resistant, being more fuel resistant, & less prone to fading. The automotive type paints are way more money though. The Deere synthetic enamel is probably the best of the cheap paint... The TSC type paints are very prone to color change [usually turn a bluish purple] & fade real fast.. ~The thing to keep in mind in paints is within reason the more it costs the better it is. Paints like synthetic enamel [Deere Paint] are at the low end of the spectrum.. ~One of the problems with Deere synthetic enamel is it never gets really as hard as the acrylics even with a synthetic hardener added.. Therefore it is somewhat scratch prone & does chip easier with hardener added.. [In my opinion it is still the best for the low initial cost though].. ~Personally I like the look of the Deere synthetics as they tend to dull a little with time & look more like a tractor than a sports car.. It kind of gives the tractor a warm more original look.. ~If you use Deere synthetic enamel it seems to paint out better if the Deere enamel reducer isn�t used but a good quality [correct temperature range] name brand synthetic enamel reducer is used. The same with hardener, it needs to be synthetic & NOT acrylic hardener.. If you do use the hardener use a fresh air supplied face mask & keep your skin covered as the iso�s in that hardener can cause lasting medical problems & a sensitivity to other chemicals.. Do a search on Isocyanates before working with those evil chemicals.. [email protected]
