JD 50 Brake Noise
BillS
02-28-2005 11:05:23
The left brake on my 50 has a very loud vibrating noise which stops if I step on the pedal a little bit. I had turned the drum awhile back and used the same brake linings as they weren't too bad. I took the drum off now and everything seems to look OK. My parts manual shows s washer on the shaft under the brake drum and mine doesn't have it. Would that be the reason for the noise?
Mike M
02-28-2005 11:41:54
 Re: JD 50 Brake Noise in reply to BillS, 02-28-2005 11:05:23
Just a thought that popped into my head. You say pushing the pedal a wee bit helps ? Could the pedal and or stop be worn a little and is it possible if it goes up too far it cams back over the other way ? If so a little weld built up on the worn stop could help. Those shim washers are used to control end play of the brake shaft. I can't remember how much is acceptable and what is excessive. You don't want them too tight.An I&T manual may have the spec. in it.
