50 oil check
Bill46
02-28-2005 05:57:23
Just got my first JD. Always wanted a 50, now I have one. Not in the best shape...but runs well.
Question though, how in the world do you check the engine oil? I am used to dip sticks and pet cocks on the older red tractors.
A friend told me to pull a plug under the pulley. Is this right? Please help as I do not want to run it a lot until I can check everything properly.
A photo would help if you have one handy.
Thanks in advance.
JYD
02-28-2005 09:07:20
 Re: 50 oil check in reply to Bill46, 02-28-2005 05:57:23
Bill46,
In the left column of this YT page under "Galleries" click on "Parts & Pieces". Search for "John Deere Model 50" and you will find a graphic that will show you the important locations on your Model 50 that pertain to checking/changing the oil. I posted this graphic last week for another new Model 50 owner. Good luck with your new tractor.
JYD
chrisfromsolitude
02-28-2005 08:06:41
It has a small "petcock" under the belt pully. It sticks out from the crankcase and has a plug in the end of it. Turn the plug out and oil should run out the bottom of it. I don't have a picture but you should be able to find it. Hope this helps and enjoy your new John Deere.
Bill46
02-28-2005 09:44:04
 Re: 50 oil check in reply to chrisfromsolitude, 02-28-2005 08:06:41
That did the trick. Thanks loads for the help.
