Info about JD 830 3cylinder
xlr82v2
02-27-2005 23:52:47
I've come across a JD 830 3-cylinder diesel that I'm considering purchasing. I know that these tractors were made in the early 70's, possibly 73-75 I think?
Anyway, does anybody have any experience with these tractors or know what to look for as far as problem issues to look out for when purchasing one?
Any and all info is greatly appreciated.
Thanks!!
Brian
jdemaris
02-28-2005 06:40:32
 Re: Info about JD 830 3cylinder in reply to xlr82v2, 02-27-2005 23:52:47
I thought this question was just asked recently, maybe someone else? 830 is basically the same tractor as the AG. 1020 or the industrial 300. Only major differences that I am aware of (besides being assembled in Germany) are the options that were availble. One is the optional 135 gas engine that was available in the U.S. built 1020 and 300. I could be wrong, but I know that all the 830s that we sold only came with the 152 diesel - and it's likely that's all that was used in Germany. They like Rudolph Diesel over there. As far as problem areas - I can't think of any, they're great little tractors. Only issue that applies to almost all Deere tractors with closed-center hydraulics is starting. If not set up properly, they're hard to start when hot and eat up starter motors unless you put a destroker on the hydraulic pump. You can do it for less then $10.
jdemaris
02-28-2005 11:19:30
 Re: Info about JD 830 3cylinder in reply to jdemaris, 02-28-2005 06:40:32
I just checked my Deere books on the 2040 and others and all I find is closed-center
hydraulics. Same pump fits all of the following, with keyed shaft and 23 cm cubic cm.
pump -
1020, 1520, 1530, 2020, 2030, 2040, 2155, 2350, 2355, 2440, 2550, 2555, 2630, 2640,
2750, 2755, 2855N tractors, part # AR103033-R. With splined shaft and the 40 cub cm. pump fits 2020, 2030, 2350, 2355, 2440, 2510,
2520, 2550, 2630, 2640, 2750, 2755, 2840, 2855N, 2940, 2950, 2955, 3010, 3020, 3150,
3155, 4010, 4030, 5010) tractors. Replaces AR97872-R. I have put the bigger splined shaft pump on the smaller tractors like the 1020, and 300,
so I know it will fit. I belive I�ve also done if on the 830s. No matter what size, or keyed or splined drive, they are still all closed-center piston
pumps.
Tx Jim
02-28-2005 10:27:07
  JD 830 3cylinder hyd's in reply to jdemaris, 02-28-2005 06:40:32
I think they were open center hyd's same as early 2040's.Tough little tractors.Tx Jim
jdemaris
02-28-2005 10:48:25
 Re: JD 830 3cylinder hyd's in reply to Tx Jim, 02-28-2005 10:27:07
Open center? Not any that I've seen. We sold a few and my neighbor owns two 830s. Both have closed-center hydraulics with 8-piston pumps. I'm not sure I've ever seen a 2040, but maybe my memory is bad. I've owned a 1020, 2020, 2520, and a 2030, and all of them had closed-center hydraulics. I've also worked on the bigger 40 and 50 series tractors and they too all have closed-center hydraulics. I worked for Deere dealers from 1966 up to around 1991, and don't recall ever seeing a Deere ag. tractor with open-center hydraulics built after the 1010/2010 series. Correct me if you have, I'm interested. Give me the years if you know them and where they were sold or manufactured.
buickanddeere
02-28-2005 13:49:10
 Re: JD 830 3cylinder hyd's in reply to jdemaris, 02-28-2005 10:48:25
Everything Waterloo,Dubuque and Mannheim from the 20 to 55 series was closed center hydraulics. What out for the Mr. Tinkers who can't or won't read a manual. If gear oil has been dumped into the transmission. Run away from that poor abused tractor. Take a ph test strip plus a regular and check the engine coolant too. If acidic or weak, walk away from that tractor.
HTR
02-28-2005 15:06:35
 Re: JD 830 3cylinder hyd's in reply to buickanddeere, 02-28-2005 13:49:10
I think all of the 820 and 830 three cylinders were open center. They had a gear pump in the same location that the piston pump is usually. If they were equipped with power steering, there was a second gear pump stacked for steering only. The return oil from the steering returned to the inlet side of the gear pumps to help the the transmission pump keep up. I have only worked on one 2040, it had open center, gear pump arrangment. I think the later 2040 went to closed center, not sure.
The early 1020, 2020, 40x forklifts, and probably other equipment, were closed center with a timing cover mounted gear pump for open center steering.
jdemaris
02-28-2005 17:34:53
 Re: JD 830 3cylinder hyd's in reply to HTR, 02-28-2005 15:06:35
Only 820 I ever saw was a 50s vintage 2 cylinder tractor. The power-steering pump on the timing cover for Deeres in the late 1960s was common, the 350 and 450 crawlers had it also. It was often used on tractors that also had closed-center hydraulics for reasons I can't figure. But, 830s with gear pumps? I'd like to see a photo or a parts list. I've worked on several 830s, and my neighbor has two he's owned since new (he bought them new from the dealership where I worked). Both of his 830s have 8 piston closed-center hydraulic pumps. They are the smallest of the 8 piston series, we used to called them the "German pumps." There were a few other tractors that also had them, I've rebuilt plenty. End cover on the pump takes a gasket instead of o-rings, the shaft is keyed instead of splined, and the stroke-control valve is different than the bigger pumps and adjusts with a screwdriver instead of an allen wrench. We swapped some of those pumps out with bigger spline-drive pumps 8 piston pumps for loader use. So, you've got me very curious. I'd like to see something that shows it, and I'm going to dig up my 830 parts microfiche. The 830 tractor you speak of, you actually saw the gear pump on it, and it was a tractor built for U.S. import?
HTR
02-28-2005 20:32:34
 Re: JD 830 3cylinder hyd's in reply to jdemaris, 02-28-2005 17:34:53
You made me do some searching. The book says 820 three cylinder 1968-1975, 830- 1974-1975, 2040- 1976-1982. I went to John Deere parts on line. They show three pages of the pumps, all three show gear pumps for 820-830, does not show a radial piston pump, but only refers to open center on one picture. The 2040 shows gear pump up to serial no. 349999, piston pump over serial no.350000.
As far as I know all the 820-830 three cylinders were German built. Most in this area were used for running PTO crusters in chicken houses. They were small and easy to maneuver inside.
I have also, rebuilt many of the small four and eight piston pumps, most of the problems were leaks, or the allen head plug that held the inlet valves coming loose. They used bushings instead of bearing on the crank/cam shaft, that didn't work out too well either, if you ran a hydraulic motor constantly. I have installed some thirty gallon pumps in 2030s when the crusters went all hydraulic drive.
Tx Jim
03-01-2005 03:56:56
 Thank you HTR!!!!!!!!!!!!! in reply to HTR, 02-28-2005 20:32:34
Thank you for backing my statement on open center hyd's.I was beginning to think my CRS was worse than I had thought.I never could figure out why those open center SCV's had to have so many lines to valve.Tx Jim
xlr82v2
02-28-2005 23:32:10
 Re: JD 830 3cylinder hyd's in reply to HTR, 02-28-2005 20:32:34
Went and looked at the 830 today in the daylight...
The hyd pump does NOT look like a piston pump, but like an aluminum bodied gear pump. I would say it's much too small to be a piston pump (compared to the hydraulic piston pumps I've seen before).
I agree with the guys that say it's Open Center hydraulics... I didn't see a hydraulic accumulator anywhere in front of the radiator near the pump like what a 4020 has. Just a pump at the bottom, air cleaner above the pump, and fuel tank in the front. No accumulator. So, that tells me "Open Center".
jdemaris
03-01-2005 05:50:36
 Re: JD 830 3cylinder hyd's in reply to xlr82v2, 02-28-2005 23:32:10
I believe you guys, and wasn't claiming they don't exist - just haven't seen it. And, now . . . why do my neighbor's two 830s both have piston pumps? We sold him the tractors new, but to tell you the truth, never had to think about it much before. We've compared our tractors a few times since I've got a yellow 300 industrial that appears to be identical to his 830s except mine has the a big 2.4 cubic inch, spline-drive pump that I installed some years ago.
