JD 2440 and JD A (Pulling power)
GNB
02-27-2005 17:34:48
I have a 1950 JD A and have just bought a JD 2440. I would like to find a pull type off set disk Harrow that both will pull. I dont use the JD A very often but would like to work the old girl every now and then and want something that would work on both. What size should I look for? Is both tractors about the same as far as raw drawbar pulling? I know the 2440 has lots more horses but the A is probally a little heavier or close to the same.
GNB
thurlow
02-28-2005 05:20:43
 Re: JD 2440 and JD A (Pulling power) in reply to GNB, 02-27-2005 17:34:48
The offset disks (Rome, JD) with which I'm familiar require some serious HP, in the neighborhood of 10-12 HP per foot of cut. These are often termed "new ground" disks locally. I know that in some localities, there were some one-way/offset disks made and used which were much lighter and used for the same purposes as tandem disks.
CLW
02-27-2005 22:56:06
GNB, as a kid I worked for a gentleman driving a 49 A gas. We pulled a one way the first two years and then he got an offset disk. (Case, I think) It was 47 years ago so I don't remember the width but I do remember it was just wide enough that it would cover the tracks of the tractor.(6 1/2 to 7 ft. I guess) Was a good fit for the A on four of the five farms he had. The fifth farm had some areas that were sandy and it would sure make her talk when we went through the sandy area. It did a good job.
CLW
Indydirtfarmer
02-27-2005 17:59:41
I've got a 2440. It will pull 3x16" plows with relative ease. I TRIED a 4x14", ONE TIME, and decided that would kill the tractor in short order. I have a 12' and an 8' disc that it will handle. 12' is more of a finishing disc. The 8'er is weighted down heavy. It digs in to sod real good. Not even a good load on the 2440. Never had an offset disc. No clue as to how much of one the 2440 would handle. They are USUALLY quite a load. I've always heard you should use one 2/3rds of the size of a conventional disc.
