720D Knock - Cont.
Kevin L.
02-27-2005 08:26:01
After droping one cylinder at a time while runnning the knock did not disappear on ether cylinder but after listening more to the sound and thinking more about it, it sounds more like what I remember hearing in machines when a bad bearing is dry of grease, but before it comes apart and the big trouble happens. Now I'm hopeing this noise is not the left main spinning in the housing that I'm hearing. With a crow bar under the flywheel I am finding what I feel would been above normal play there and also in & out play with the crow behind the flywheel but do not see this play in the mounting point between the flywheel & crankshaft. Have consider replace the flywheel bolts and retorquing but don't think the sound is from there. Just trying to get some troubleshooting ideas before putting the tractor back in the basement to removing the flywheel or the main bearing and what knid of fun am I looking at there. Just hate to know I can not listen to that sound til it's back together and thanks for replies.
