# 60 john deere decompression lever
Herb S
02-27-2005 08:02:09
Hi on my rowcrop #60 there are 2 decompression levers one for each cilinder ,but this standard #60 lowseat doesn't have them,dus any one know if i can have them put in,because the tractor is hard to start below -15 celcius thanks Herb S
JD hauler
02-27-2005 19:35:06
 Re: # 60 john deere decompression lever in reply to Herb S, 02-27-2005 08:02:09
are you sure the tractor didnt get retrofitted with a 6-3 powerblock?, they dont have any petcocks.
Randy Stoudt
02-27-2005 16:54:09
Has anyone tried two 8 volt batteries with any seccess? One 8 volt in a 6 volt tractor works good. 16 volts in a 12 volt system. Will it work?
Herb S.
02-27-2005 14:55:16
Thank you guys out there for your suggestions . I will take them to my shop tomorrow to my old johnny my deere. I think the idea of putting a block heater in would be my easy way out. Thanks again. from Herb
P.S. I did find amongst all the rust the two pet cock plugs.
Kevin L.
02-27-2005 12:05:49
oops, I screwed that one up by not reading the parts books, thought it was a washer by the picture but by reading the description it's not. But now knowing that, that option is available I see now how one could hand start the tractor with the steering wheel and the crank wrench in the flywheel by the operator's manual if he was real ambishous..
big jt
02-27-2005 10:37:39
Like the others said if the block is a Original 60 block there should be a hole on the bottom of each cylinder with a plug or petcock.
One other suggestion. Are you just cranking until the engine fires? On mine the carb drains down if the tractor has set a while (habit of the duplex carb). Has the oil pressure fuel shut off also. All I do is crank until has oil pressure, stop to let the carb fill and about the time the pressure guage goes back to the pin, hit the starter again and usually fires.
You can override the fuel shutoff but I have a heathouser on the tractor so the "crank stop start" method is easier.
JM2CW
jt
F-I-T
02-27-2005 10:21:26
Herb:
Per the parts book, the A 4242 R pipe plugs should be present in the block. Those would be removed and then you can install the petcocks AB 1898 R in those holes.
That should help it spin a bit easier.
Frank
bent
02-27-2005 09:52:49
Herb, there may be petcocks under the block but it would be a bit impracticle to use them. I have a low-seat with two big 6 volt batteries (as big as will fit through those openings!) I had the starter re-built a few years back. I have no trouble starting it up to -20 Celcius, but after that, it needs to be plugged in. A circulating block heater works wonders.
Bent
donmyeil
02-27-2005 08:43:22
look under the frame at the bottom of the block. either they are there or plugged with pipe plugs. sounds like you need a starter rebuild and/or batteries .
Kevin L.
02-27-2005 08:39:29
If you are talking about petcocks like on the model B to help in hand starting the motor, don't know that a model 60 orignally had that and sure don't remember seeing that shown in the parts manual, they worked in the lettered version tractor, just some questions to think about, the mounting height in the cylinder wall for how much could get released, would it work if the cylinder was sleeved and missing water jackets.
