jdemaris
02-27-2005 07:10:04
Re: 2010 gas wiring diagram in reply to Deerly Parted, 02-27-2005 05:52:19
The basic principles aren't any different than for any most other engines. If you've got power getting to the coil, and the coil is hooked to the points, and the points are operating correctly, it should work. 1010s/2010s did have a convoluted system for the ignition resistor. Originally, it was built into the ignition switch and later, Deere came out with update kits to change if over to a separate resistor. So, God knows what you have. Check for power on one of the coil primary terminals. Then, check the other primary is making its way to the connection on the ignition points. Also ascertain there is a condenser hooked to the points and that it is not shorted or dead. Leave the distributor cap off. Leave the coil wire plugged into the coil (at the coil end of the wire). Have the other end of the coil wire hanging an 1/8" from ground - or hook it to a grounded spark plug. Get the points open. Now short them with a screwdriver, knife, tomahawk - whatever works. Every time you short the points, you should see a spark jump out of the coil wire to ground. If you don't - you've narrowed down the problem to the coil - assuming you've checked the other components properly. If you HAVE spark, now do the same test by cranking the engine and letting the points open and close on their own. If you still have spark coming from the coil wire - move on to testing the secondary system of the spark distribution - i.e. put the cover, rotor, and cap back on, plug the coil wire back into the cap - and now crank and test for spark from the spark plug wires. If no spark - then you've got distribution problems somewhere in the cap, rotor, etc. If it still doesn't work - I'll give you a $100 bucks for it. I could use extra parts for my 1010. Generally speaking, 1010/2010 gas engine doe not start well in cold weather, even with a properly functioning resistor bypass, unless it has the correct coil. Warm weather it won�t matter. If you buy a conventional coil from your local auto parts store rated for 12 volt use and an external resistor, it will not work as well as the coil that is made for the system. As far a rewiring the resistor bypass if needed. If you have a Delco starter, it�s easy. Just use the �R� terminal on the solenoid. If you have a Prestolite starter, then add a relay or buy yourself a temperature sensitive resistor like Ford uses in the 172 c.i. 4000s and such. Or, don�t use a resistor and get ready to change points more often. Or, go electronic and breakerless and you won't need a resistor.
