3010 loses power
steve wi
02-26-2005 19:07:02
I have 3010 with 148 loader and when I put the loader on it seems to take power away from the tractor even if I don't use the loader. I disconnect the loader it's fine. Any idea why the hyd. pump is working so hard.
Mike Becker
02-27-2005 17:44:17
 Re: 3010 loses power in reply to steve wi, 02-26-2005 19:07:02
I agree with the last post. You are running a open center valve on a close center tractor. Some valves are conversible, like a Cross valve, some are not. I have seen a blown o-ring on the out port and oil will pump through. The large hex nut on the outside of right side of the valve should have the letters "CC" stamped in the center, it it does not it is an open center valve. Also the plug just to the left of the handled spool valves should be a flat hex not stepped with a acorn nut on the end. Both pieces will have to be changed to make it closed center. You can run an open center valve on a closed center system and oil will heat up and motor will pull like you described but not a closed center on an open center system.
msb
02-26-2005 19:44:01
Does the hydraulic oil seem to get warm fairly quickly? Can you effectivly use more that one function on the loader all at the same time?When using two functions at the same time are they considerably slower that using just one function?
Bob
02-26-2005 19:34:38
Apparently, your loader has it's own control valve?
The control valve on the loader MUST be set up for a CLOSED CENTER system to match the Deere.
