4430 hydraulic
gordon hulgan
02-26-2005 09:41:10
Tim it may be the stroke control value is sticking. it is located on top of hyd.pump (in front of engine} you will need a special tool for that but is realatively simple. hyd rough up down try caterpillar hyd additive 1u-9891. use alot in hydraulic Elevators.
Tim A.
02-26-2005 19:19:51
 Re: 4430 hydraulic in reply to gordon hulgan, 02-26-2005 09:41:10
Gordon,
Thanks for the info. If the stroke control valve is sticking, would it probably need to be removed and cleaned, or would the valve and maybe spring have to be replaced? By using the additive you suggested, would this possibly 'unstick' this valve if it is the problem? Just to make sure, I can add this additive to the Hy-Gard (sp?) fluid in a QR Trans?
After reading your post, I looked in my IT Manual and it said that if the tool was not available, you could put the exact same thickness shims back in the unit, then add or remove them to raise or lower cut-in pressure respectively. If I took the valve out to inspect it, what would I be looking for to determine if there was a problem there? Also, you mentioned that this was not a big job...can it be done without removing the radiator etc like it says for removing the whole hydraulic pump? Also, the IT manual talks about adjusting the manual by-pass valve (only if using a loader, if necessary)on early model tractors...mine is very early...1973 model. Since my loader seemed to work fine for a period of time, then things changed, this is probably not an issue.
I also have 2 other questions...not at all related to the hydraulics. 1) The PTO shaft sometimes (more often than not) turns when the PTO is not engaged...it does not do this under load, but I have noticed it when I was hooking up an implement etc. Is this something to worry about and what is causing this? 2) An even more unrelated question, my tractor only has a hand throttle...is it possible to add a foot throttle and what kind of a job is this? Something I was thinking about for the distant future...have too many irons in the fire now!
Thanks Again,
Tim
gordon hulgan
02-27-2005 11:47:36
 Re: 4430 hydraulic in reply to Tim A., 02-26-2005 19:19:51
Tim call me @423-322-0141. Or E-mail me a number I call you. that a tenn. number but im in ala. to much typeing to answer all questing?
Tim A.
02-27-2005 18:14:51
 Re: 4430 hydraulic in reply to gordon hulgan, 02-27-2005 11:47:36
Gordon,
Was about to call...but my wife reminded me that it is 1 hour later where you are at...so, did not want to call after 9 pm. What would be a good time to call you?
Thanks,
Tim
Tim A.
02-27-2005 12:18:06
Gordon...thanks a whole lot...will try to call this evening..
Thanks Again
Tim
