2510 questions
JW
02-17-2004 16:19:44
This is a little late since I already bought one but I have a few questions. Will a 2510 gas syncro pull a six row 7200 planter with no fertilizer(finger not vac). Also how hard are they on fuel?
jd520
02-17-2004 20:12:38
 Re: 2510 questions in reply to JW, 02-17-2004 16:19:44
i don't think you will have any problem. this last spring we pulled a 8 row 30'' planter jd 7000 with a 730 gas .it handled it real good. it was a perfect match for it . but it only planted a 40. it worked out good because it did not tie a bigger tractor up. old dad pulled a jd 7000 4 row wide with a little 520 also.talking about a highly productive piece of equipment.thanks
John51
02-17-2004 17:33:34
It should pull it easily. I use a 530 (about 40hp) on a 4 row with fertilizer all spring. As for fuel...not bad. It's hard to compare unless you have another tractor doing the same job under the same conditions.
